Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 06-28-2007, 09:27 PM   #1
starflyte1
starflyte1's Avatar
Profile:  2007 25' Safari FB SE
Bonita Springs , Florida
Air conditioner works, but not cool
We are in Seattle fortunately. It is going to be cool here for the next three days. Our ac works, fan only works, but the compressor tries to come on to cool, but just doesn't make it.
Any ideas? The fuse wasn't tripped, so that does not seem to be the problem. I will ask my husband about the capacitors, mentioned in another post.
Camping World is booked for weeks. We will have to get it fixed before we start home.
Thanks for any ideas.
Pat
starflyte1 is offline   Reply With Quote
Old 06-29-2007, 09:47 AM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Pat
Are you using an extension cord?
If so, what is it's capacity or rating?
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 06-29-2007, 09:54 AM   #3
starflyte1
starflyte1's Avatar
Thanks for the reply.
We are plugged into 30 amp at Seattle KOA with the heavy cord. The ac worked for the first two two days. We have the volt meter and it stays in the ok range (per husband).
We tried the heat strip this morning, and it tried to work but just never made it. The fan only mode works.
Thanks again.
Old 06-29-2007, 11:12 AM   #4
0557
Profile:
Thanks again.
I don't want to be a bringer of bad news, but my dometic A/C was plugged into a so-called 30amp box at my campsite for 6 months. after the 3rd month in the middle of July, the unit only worked in fan mode. I got the park tech to do a load check at the source and only had 18 amps max on full load, SO i had burned up the compressor. You need to be sure that the box is sufficient voltage and amperage for your unit to run your appliances.
0557 is offline   Reply With Quote
Old 06-30-2007, 12:58 PM   #5
starflyte1
starflyte1's Avatar
0557C, I think that is a possibility. Someone is coming to look at it Monday evening. Will he be able to check the campground supplied power, or can one of the office people check it?
It is cool here so we are very lucky. We called several Dometic repair places, including the repair center in Portland and the AS dealer in Kent. No one would help for several weeks, and we can't start home until it is fixed. KOA gave us the card of an independent repairman. We will have to pay, but at least it will be fixed or replaced.
I am a little dissappointed that neither the local AS dealer nor Dometic repair center could help us. The AS dealer asked if we bought it from them. If not, no help for weeks. I knot that is common with SOBs, but did not think that AS dealers were like that. Even thought about going back to Spokane to the great, helpful dealer, Nick. But, we are trying to go down the coast on the way home.
If we have to wait for repairs, Seattle is a pretty good place to be waiting!
Pat
Old 06-30-2007, 10:05 PM   #6
starflyte1
starflyte1's Avatar
0557
The service man just left-he had an emergency call in the park, so came here two days early.
The hard start kit had "blown" because of lack of enough power, just as you said.
In the furure. I will turn off the ac before using the micirowave, hair dryer, toaster, etc., just to be on the safe side.
Pat
Old 06-30-2007, 11:24 PM   #7
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Unfortunately not un-common
Pat
Pat,
Your expereince is un-fortunately not un-common. I asked Sutton to help me with a warrenty problem. Since I did not buy it there they were very reluctant. I will be having a conversation with Dave Schumann when I make my hopefully final stop at the Factory in December. I suggest you report your expereince to Dave.
Michelle
I'm not afraid I learned to drive in Washington, DC
Sarah
Ruby, (05 BMW R1200RT) serviced and put to bed for the winter
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Classic 31 w/dinette, solar)
http://Michelles-Adventures.US
Old 07-01-2007, 02:40 AM   #8
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
0557
Pat
On most newer RV air conditioner units, it is very common to burn out the start capacitor and PTCR (positive temperature coefficient resistor) when using the unit in hot/humid conditions ...OR.... when you are stressing it by adding an additional load to the trailer 120VAC wiring, such as a hair dryer or microwave.
In effect, it leaves no 'head room' for the capacitor to draw from when the compressor starts and calls for the extra voltage boost while the other appliances are drawing the excess amperage, so it burns out. It might not be a bad idea to carry an extra set of capacitors in your trailer as a safety measure.
BTW, they ARE covered under your Dometic warranty and you should report your experience and demand re-imbursement from either Airstream or Dometic directly.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 07-01-2007, 02:45 AM   #9
3Ms75Argosy
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
how...
does one replace the start capacitor and PTCR? I don't know what I'd be looking for up there?
Is there an exploded page with parts you can post?
Thanks!
Marc
Old 07-01-2007, 11:40 AM   #10
lewster
Commercial Vendor
lewster's Avatar
Hi Marc,
It's a process that's not difficult:
1. turn off the 20 amp breaker to the A/C
2. remove the top shroud (2 screws in front and 2 at the back on either side)
3. on the curb side of the unit, you will see a metal access panel that is about 6 X 6 on the curb side of the evaporator. It has 2 hex head (5/16 IIRC) holding it on. The left side screw might be hiding under the foam tape.
4. remove the panel and it reveals a circuit board and beneath it.....a large and small capacitor. If the PTCR is burned out (most likely) it is the little box that is plugged in to the smaller (start) cap and is connected to the top of it.
5. CAREFULLY remove both capacitors and you will either see a small burnt blob on the top of the start cap (smaller one) and/or a bulging or leaking start cap. The larger one (run cap) is geneally not effected by this and can usually be left in place.
6. DIAGRAM THE WIRE PATHWAYS before removing any wires, then replace the defective parts. If your PTCR is burnt, replace the start cap anyway.
7. button up the unit, but the breaker back on and start the A/C. It should be fine now.
8. go have a cold one and don't forget to pin your junior RV Tech wings on!
AIR # 10325
Old 07-01-2007, 11:58 AM   #11
3Ms75Argosy
1963 24' Tradewind
You are so COOL! : >
Thanks Lewster!
Marc
Old 07-01-2007, 06:11 PM   #12
lewster
Commercial Vendor
lewster's Avatar
:d :d :d :d :d :d
AIR # 10325
Old 07-01-2007, 07:35 PM   #13
herrgirdner
Profile:  Currently Looking...
Afton , Virginia
RGR, Lew, Let'm ROLL!
herrgirdner is offline   Reply With Quote
Old 07-01-2007, 11:57 PM   #14
lewster
Commercial Vendor
lewster's Avatar
Well,
'Les bon temps roulet' are DEFINITELY rolling..............Having a great time here in Hood River, OR relaxing, unwinding and participating in all of the extreme sports that the area has to offer..........including all of those awesome micro brews!!!!!!!!!!!
Will be semi planted here until mid Sept. Have some work scheduled at the huge FMCA convention here in Oregon, and the Monaco pre-rally also. They are both in the beginning of July. Then it's on to No Cal for an American Coach rally, and then off to the Balloon Fiesta.
I have some shots of the surroundings that I'll be posting in a couple of days.
AIR # 10325
Replacing air conditioner exhaust fin? caadoptees Furnaces, Heaters, Fireplaces & Air Conditioning 1 10-16-2006 06:57 AM
Tiny fan to bedroom of Sovereign helps cool and warm the space Joan D'Andrea Cabinets, Counter Tops & Furnishings 2 11-02-2002 12:10 PM
Skinner air valve part # benbailey Airstream Motorhome Forums 1 10-19-2002 10:03 AM
Cool lites Action Link Archive 0 09-13-2002 12:24 PM
Air streams in New York area?!? mitchm71 Our Community 0 07-25-2002 10:33 AM
test
