Old 09-10-2007, 01:58 PM   #43
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Originally Posted by Minnie's Mate
Now my next safety equipment is going to be some fold flat safety cones I saw on RV Road Trip with the battery powere flahing red light on top and some fold up safety triangles in case I ever have a flat or other break down 'cause you can never be too prepared and never have too many gadgets!
If you have a Northern Tool near you Tom, you can get these items there at a competitive price.
Randy
Randy and Pat Godfrey
Region 3 2nd VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 09-10-2007, 03:16 PM   #44
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
There is one in Stockbridge which is 30 or so miles away...in Atlanta that's just around the corner!
Family of Disney Fanatics
WBCCI# 4821
Old 09-13-2007, 11:19 AM   #45
starflyte1's Avatar
2007 25' Safari FB SE
Lady Lake , Florida
I just bought a digital voltmeter and checked the voltage in our tt. I thought that the $20 meter we had might not be reading correctly because at almost every campground, the power reading was low. 108-110, sometimes lower. It also read 108-110 at home at the 30amp outlet we just had added.
With the digital voltmeter it reads 115.6. We are leaving soon on a trip across the country on I-10, so now will have an accurate check of the power when using the ac.
Pat
Pat
AIR# 16756
WBCCI# 6167
starflyte1 is offline   Reply With Quote
Old 09-13-2007, 11:35 AM   #46
richinny's Avatar
2011 34' Classic
that $20. meter might have a calibration adjustment on it somewhere.
Ricky
Old 09-13-2007, 12:49 PM   #47
grantb4's Avatar
2005 22' Safari
San Juan Capistrano , California
What are you going to calibrate it with?
At what voltage and air temperature are you not going to use the A/C?
grantb4 is offline   Reply With Quote
Old 09-13-2007, 12:58 PM   #48
richinny's Avatar
2011 34' Classic
i usually calibrate them with a screwdriver, using a reliable meter as a guide. i'd use the best voltage i had available. as for air temerature, my a/c gets turned on at about 72 degrees fahrenheit so i guess i would not use it below that unless it was very humid.
Ricky
Old 09-24-2010, 11:47 PM   #49
A 7th year newby
IndyAnne's Avatar
1968 24' Tradewind
Indianapolis , Indiana
Images: 8
Send a message via Yahoo to IndyAnne
Bump: AC Start Capacitor & PTCR
I'm bumping this thread because I need to check out my Dometic Brisk Air AC that I had installed on the 68 Trade Wind, in 2007. It worked very well until summer of 2009. I suspect low voltage and improper wiring led to burning out the start capacitor and PTCR. There could have been a fire.
The breaker switch heated to the point that little bubbles began to form in the plastic, smelled awful. Since that time, the compressor tries to start, but does not continue. Hot days are supposed to end this weekend for a while.
Improper wiring means the installers did not locate the factory 110v wire located in the roof, between ribs at the proper location. Instead, they ran an extension off the one breaker. Trying to run too many things through the same 15 amp circuit overloaded and created a low voltage situation.
I hope the compressor isn't a total loss. Before I found this thread, I just today had the AC removed from the roof, and I intend to install a Fantastic Vent in its place. This should be good for the rest of fall, tailgating and camping.
If the start cap. and PTCR repairs do the trick, I might put the AC on eBay. I was not comfortable with the slight sag on the roof caused by the AC.
I will continue to search the forums for options on locating the AC other than on the roof. As some have said, I've not been happy aesthetically with the big white bump on the top, I prefer the lines of the simple original shape.
I'll check back with a progress report and photos. This is a great thread, possibly could be a sticky on AC Start Capacitor and PTCR.
Anne
Indianapolis, IN
TAC IN-7
1968 Airstream Trade Wind
2005 Chevy K1500 crew, reg. bed, 4WD, gas
IndyAnne is offline   Reply With Quote
Old 09-25-2010, 12:04 AM   #50
lewster's Avatar
Naples, FL , Hood River, OR
ANNE,
Your roof A/C unit should be isolated on it's own dedicated 20 amp breaker. That means that nothing else is drawing from that breaker of hot supply line. Any other configuration is against RVIA standards and just plain dangerous!!!
Old 09-25-2010, 12:20 AM   #51
A 7th year newby
IndyAnne's Avatar
1968 24' Tradewind
Images: 8
Hi, Lew -- Thank goodness an overheated breaker stinks so bad! That's why I went ahead and had the AC removed today. And, have you seen the burned out Airstream on eBay now? That's a very scary scenario.
I don't have the equipment or overhead system to take care of a rooftop AC myself. If I'm going to have AC, I will have one I can deal with by myself.
Having a vintage Trade Wind is a choice that has a lot of other choices along the way, mostly about dealing with RV service centers that do not know Airstreams, don't want to work on vintage ones, and do not like taking instruction from a customer (especially, a female customer). In 2006, I insisted that the techs find the factory wiring, but they insisted they had it all under control. Hindsight: I should have either insisted flat out, or left before they touched it. I equivocated, didn't know then what I know now, and now I am paying the price. I really hate throwing good money after bad.
So, down it came today, and it's sitting in the bed of my truck, and tomorrow I will look for the start unit under the shroud. I'm looking for the replacement kit online now, just in case there is hope that the compressor isn't totally lost.
But, I learned a lot -- checking the voltage every time, monitoring the voltage, monitoring the wear and tear on the electrical system. In the long run, it's on me, to know what's happening and taking the steps to keep it safe.
Live and learn? or, learn and live
Originally Posted by lewster View Post
ANNE,
Anne
Indianapolis, IN
TAC IN-7
Replacing air conditioner exhaust fin? casarodante Furnaces, Heaters, Fireplaces & Air Conditioning 1 10-16-2006 05:57 AM
Tiny fan to bedroom of Sovereign helps cool and warm the space Joan D'Andrea Cabinets, Counter Tops & Furnishings 2 11-02-2002 11:10 AM
Skinner air valve part # benbailey Airstream Motorhome Forums 1 10-19-2002 09:03 AM
Cool lites Action Link Archive 0 09-13-2002 11:24 AM
Air streams in New York area?!? mitchm71 Our Community 0 07-25-2002 09:33 AM
