Old 06-13-2015, 12:17 PM   #15
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Also be aware that if everything looks clean, coils freezing up can also be an indication of low refrigerant which may mean a leak.
I did have a freeze up on my SOB when it was new when I was down in Destin Fl. Air conditioner guy did weekly trips through the campground and stopped in to see me. He told me that running the fan at low speed in high humidity climates can cause the coils to ice. He told me to make sure the fan was in high speed to promote air flow. Did that and never froze up again while on that trip.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-13-2015, 01:04 PM   #16
Fly at Night's Avatar
2010 27' FB Flying Cloud
Fraser Valley , British Columbia
jcanavera, come to think of it - the recent problem started after running all afternoon on low!
The first day I used a/c, was on high all day. No problem.
Thanks for telling us about your experience.
Holding my breath.....and the air conditioner is still blasting cold and hard.
Fly at Night is offline   Reply With Quote
Old 06-13-2015, 01:27 PM   #17
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Originally Posted by Fly at Night View Post
paiceman, the a/c also did this when I was plugges into 30 amps at RV park.
I will look into getting 30 amp outlet, though.
Anyway, did the fan only setting for an hour and tried it again this am. She is blowing hard and cold again. For how long? We'll see. Maybe I'll get lucky and the trailer will resolve the issue itself again.
Sounds like a freeze up.. Did you have it on max cold? Can you set fan speed? If so, set high fan, but not as cool as you want it at first... Let the AC remove a lot of moisture from air then Drop Temp.
Make sure filters clean.
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-13-2015, 04:01 PM   #18
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I'm driveway camping - plugged into outlet in garage which is 20 amp, I think.
Is this too weak for a/c?
Running an AC on 20 amps can damage the unit even though it initially seems to run OK.
Lumatic is online now   Reply With Quote
Old 06-13-2015, 05:07 PM   #19
lewster's Avatar
Naples, FL , Hood River, OR
Not really....... After all, it IS connected to a 20 amp circuit breaker at the trailer, breaker box........but I would ONLY run the A/ C and nothing else.
Full load running amps for the Dometic units are around 3 for the blower motor and 12-13 amps for the compressor. That totals 16 amps, and this is measured at 90 degrees F. at lower ambient temps, the compressor draws less than that.
Since the start spike of up to 50 or do amps is transient, super short and covered by the start capacitor. There should be no problem with a true 20 amp circuit.
Just be very aware of the size and length of any extension cords you may use. As too small a wire gauge will result on noticeable voltage drop.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 06-13-2015, 07:54 PM   #20
Lumatic's Avatar
1993 34' Excella
Images: 16
[QUOTE=lewster;1636528]Not really...
Lew Farber
Not saying you are wrong. I am not claiming expertise, but the question if 20 amps is sufficient to run even a 13.5 AC has been asked on the forums a gazillion times. Every time I can remember the answer was no. If I remember correctly the claim was the initial start up draw put a strain on the compressor.
Old 06-13-2015, 10:41 PM   #21
lewster's Avatar
They run fine on a 2400 watt Yamaha generator......2400 watts = 20 amps @ 120VAC. when I was at the Dometic factory training school many years ago, 20 amp lines are what we used for bench testing and running all of the units in the training sessions too.
Old 06-14-2015, 12:26 AM   #22
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Air Conditioner Went From Big Blast to Small Blow
If a 20 amp breaker is not enough to pull a a given load, the breaker will trip, if the breaker does not trip under a given load, it is sufficient.
A 20 amp breaker will not deliver any less current than a 30 amp breaker unless or until it trips.
As Lew said, the gauge of wire and the length of the run can make a difference, but unless the run is very long, this will not make a big difference regarding the issue at hand so long as the trailer is not connected with an extension cord too small a gauge for the job.
Old 06-14-2015, 07:11 AM   #23
jcanavera's Avatar
Fenton , Missouri
Images: 143
If you can use a digital voltage tester it is always interesting to see the voltage in the trailer before and after you start the A/C unit. I have a 15K unit and have plugged in to an extension cord and have watched the voltage drop in an interior outlet in the Airstream to as low as 108 volts. Using a 20 amp adapter plug to plug directly into my garage outlet, I still saw at least a 5 volt drop. With that in mind I don't run the A/C unit while parked at home.
It's also interesting to monitor the power available when camped. I've seen it as high as 122 volts and as low as 94. Needless to say that 94 volt was an old former KOA that was bought by a first time campground owner. He had no idea the wiring had deteriorated that much. I remember pulling into the campgrounds for a WBCCI rally with the folks telling me as soon as I got there that we couldn't use the air conditioning.
Typically I keep my digital voltage meter plugged into the wall outlet in the kitchen area to monitor the campground voltage. Sometimes you start up good but as the campground fills and the air conditioners turn on I've seen some loops drop significantly. It bears watching when you are out. Due the the power needs of the water heater and refrigerator, I've switched both over to gas when voltage levels drop to keep voltage up for the A/C unit.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-14-2015, 03:34 PM   #24
Thanks again for all your replies. The breaker has not tripped, so looks like I am getting away with the reduced amp.
Air conditioner is working well again - but I do not leave on "cool" all the time. If I am going out, will change to "fan only." This seems to be the trick. However, I will get those coils looked at.
Really appreciate all your help!!!!!!!!!!!!!!!!!
I don't think I would have purchased (or kept) an Airstream without the body of knowledge on this forum! (Big hug!)
Old 06-14-2015, 06:54 PM   #25
jcanavera's Avatar
Fenton , Missouri
Images: 143
Just an FYI, reduced voltage will not cause a freeze up. It will cause your fan motor and compressor to generate excess heat which can damage those components.
Jack Canavera
STL Mo.
AIR #56
Old 06-18-2015, 09:22 PM   #26
jcnavera, until I get the 30 amp outlet, am using as little as possible. Have not used it much since purchase - thanks to our cool/wet climate.
The heat finally broke. Is raining and cool. I love it when it's like this because the windows are open and am enjoying nature's "air conditioning." Have always thought Airstream designed the best windows for the rain. You can have them fully open and not one droplet gets in (unless the wind is blowing really hard).
Old 06-18-2015, 09:26 PM   #27
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Jalousie a hard to beat for same. And nothing else quite "catches" the breeze so well.
But down here balancing the A/C against the dehumidifier is the trick.
Old 06-20-2015, 07:36 PM   #28
gr.austin's Avatar
2009 27' FB Classic
Sioux Falls , South Dakota
Just a final note
1. Yes you can run your A/C on 20 Amp all day and all night without harm.
2. The voltage to the A/C MUST be at least 108 VAC. Lower voltage at the compressor will cause failure to start. In this mode the unit will try to start a few times per hour depending on how long it takes for the compressor to cool down. It can be in this mode for several hundred start attempts without failure. Remember that if your voltage is at 108 and you have small wire 14awg or 12awg then when it goes to start the voltage at the compressor may drop below the 108 and eventually cause a failure particularly if it is very hot outside 95+.
3. The power cord to the trailer MUST be at least 12AWG wire and NOT more than 50' 10AWG would be better if length is 50+ feet
4. There is NOTHING on the roof to inspect, check or service that would cause a coil freeze-up.
5. The freeze-up is caused by only three things:
a. Low refrigerant level (Not likely on a new unit)
b. Low air flow (blocked coil, dirty filter, low fan speed) Unit voltage will not cause coil freeze up
c. Low load. If you set the unit at 65 and the RH goes to 40% it is very likely to freeze the coil. This is what I think has happened to you.
NOT to Worry
Your A/C unit has many safeties to keep it running:
1. If you have low voltage the unit will trip off on an internal safety and will only allow restarting attempts that will not ruin the compressor. (if left unattended for many days (28) then the unit is allowed to die.
2. If the unit does overheat which it is allowed it will NOT die. The safeties will protect the unit for up to 28 days.
It is a very smart not to leave the A/C on when you are not there.
Happy Camping
gr.austin is offline   Reply With Quote
Small Rooftop Air Conditioner AC Options. Please help! Trestrey Furnaces, Heaters, Fireplaces & Air Conditioning 0 05-19-2015 10:35 AM
Air conditioner went south... Bing-Bing Furnaces, Heaters, Fireplaces & Air Conditioning 12 06-16-2011 06:14 PM
air conditioner- how big and which brand? gparker Furnaces, Heaters, Fireplaces & Air Conditioning 6 07-14-2006 07:06 PM
Region 1 Rally 2004 (What a BLAST!!!) AirHog WBCCI Rallies & Events 25 08-24-2004 08:48 AM
BIG BIG AIR HUG!!! & "eh" Streamin' THANKS GT1963 Our Community 6 01-30-2004 07:50 AM
