Old 07-30-2008, 11:15 AM   #1
Airstreamin' in Canada
Waterdown , Ontario
Air Conditioner weight
How much weight would we save if we removed our original air conditioner off of our 1973 Overlander and just put a vent in it's place?
mlang905 is offline   Reply With Quote
Old 07-30-2008, 11:33 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
They weigh around 100 pounds. A vent in its place would weigh between 5-15 pounds.
Old 07-30-2008, 11:35 AM   #3
The original Ac weighs about 120 pounds.
If you remove it, the increase in the fuel economy would be about 1 gallon saved, per ball park, 5000 gallons used.
People do not travel with a full tank of water, to save fuel.
A full tank of water, reduces the fuel mileage even less than removing the AC, "AND" increases the center of gravity.
A full water tank, lowers the center of gravity, which helps stabilize the trailer when towing. Also, it's a great place to get water, when you blow a radiator hose.
Old 07-30-2008, 02:21 PM   #4
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
I was going to say around 70 lbs. Not really worth it for weight reduction. It is priceless on a hot buggy summer night escpecially when the neighbor has a camp fire going and the smoke is blowing your way. By the way Andy from inland is with it. That guy is a fountain of great information I know he has helped me a few times
mustang is offline   Reply With Quote
Old 07-30-2008, 04:16 PM   #5
Well Preserved
1993 21' Sovereign
That's about 50,000 miles of towing. I'm sure at some point in that 50K, you'll run into a spot that you wished you had the air conditioner.
Now, if it doesn't work, and the shroud is broken, and it leaks rainwater, that's another matter entirely, as it makes no sense to not do something about it.
Air Conditioner willyd Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-27-2008 08:38 AM
Air Conditioner gunner Classic Motorhomes 11 06-29-2007 06:19 PM
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 10:43 AM
air conditioner tinman7 Furnaces, Heaters, Fireplaces & Air Conditioning 25 05-09-2004 04:03 PM
air conditioner Richard Murphy Furnaces, Heaters, Fireplaces & Air Conditioning 1 01-06-2004 05:48 AM
