The Coleman Delta TX air conditioner works efficiently to cool our trailer, but I'm not sure that the thermostat is working. The fan blower runs constantly and cold air blows out, but I never hear any part of the system cutting in or out. When the trailer is cool enough, we switch off the unit. There is a low/high cooling setting on a knob, but turning this does not appear to have any effect. Air conditioning systems are new to me, as an inhabitant of an island where 80 degrees is rare, even at the height of summer. Should I hear the compressor cutting in or out, or does the compressor just work at different rates for different amounts of cooling? If the thermostat is defective, is this an isolated part that is replaceable? Thanks. Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
It sounds like the thermostat or the relay that it is attached to, may be bad. The compressor should cut out when the desired temp is reached. The fan may or may not continue to blow depending on the unit.
If starting the unit , getting cold air, you should be able to turn the thermostat to the highest setting and get the compressor to cut out.
The thermostat is a replaceable part. Most US RV dealers would be able to get it for you, I have no idea if they would be available in England.
__________________ Brett G WBCCI #5501 AIR # 49
Logic is the one way you can go wrong with confidence - Charles E. Kettering
Brett, thank you. My trailer is in North Florida, so I can get parts next fall when I return. I have listened for a change in sound, but cannot hear anything. The fan is very loud, but I expect I am hearing a constant fan plus compressor. I will find the thermostat, disconnect it, run the AC, see if the noise changes, and then aim to understand what is going on. Thanks again. Nick
The fan will run continuously on all but the Classics. You should be able to both hear and feel the compressor cycling. It will rock the trailer skightly when it starts and a bit less when it cuts off, especially if the stabilizers are not down.
The thermostat on my old International failed and it worked just as you describe. I could hang meat in the trailer at night and my wife slept under 3 blankets. With a new thermostat, it was fine.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2007 Silverado 2500HD Duramax/Allison LTZ
WBCCI Region 9 Webmaster, #9632
John, thanks for that. So that's why your trailer was rocking. I've fitted a battery powered wall-mounted digital thermostat to control the furnace, and this thermostat is also able to control cooling. I assume the AC is switched by a relay, which is switched by a low current through the thermostat. If I intercept these switch wires, I assume I could lengthen them and connect them to the wall thermostat. I could pass the wires over the roof and down the refrigerator vent, or try to feed a wire between the skins to the back of thee refer, which is close to the wall thermostat. Would this work? Has anyone done this? Any advice?Thanks. Nick.
It depends on if the thermostat is a high current device or not. If it is a low current device it would work. Most thermostats have low voltage contacts.
Nick, sounds like you are back in England! Give me a ring when you come back next fall and I will help you troubleshoot it. PM me and I'll give you my Florida landline number.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce! Air # 283
