I've recently bought a 1972 29' International land yacht. The orginal armstrong air conditioner is shot. I'm not sure what BTU unit is on my Airstream now, but wonder if it would be wise to upgrade to a 15,000 BTU vs. a standard 13,500 ? I live in Texas and want it cool inside. Any recommendations on Duo-Therm vs. Coleman.
I would go with 15,000 BTU. Mu 13,500 BTU will drive us out of my 22', but friends with larger trailers and 13,500 BTU complain about insufficient cooling. Better too much too little.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Drain pans are not avaiable for any 15,000 BTU AC.
However, we will have a pan for the Carrier 15,000 unit in about 2 weeks.
Also the Carrier AC has oscillating front and rear vents that adds a great deal to the circulatuion, and it also has an "air shower" that you can turn on, to get a fast straight down current of air, so that you can quickly cool off when coming in from the hot outside.
And most importantly, the Carrier costs less than the other brands.
There is a 15,000 btu air that dometic makes and Airstream does supply a pan for this A/C it is an option on there new Classic trailers. if you go to there online parts book you can get there part numbers there.
Parts Book Look at this PDF file and it links you to the A/C and there part numbers from Airstream
Pan number is #961270
A/C number is #690323-37 This is a 15,000 with heat pump but Dometic does make same style A/c without.
When my Armstrong goes bad I will be putting a 15,000 btu on.
I have already confirmed they can get the above items. I did this by calling there tech line and parts department. They told me I had to go to an Authorized dealer to order them though.
The A/C pan is about 60.00 retail from an Airstream dealer.
You can get the A/C at Camping World for retail at about one-half the Airstream quote. Dometic A/C's are used on many types of RV's and are not an exclusive Airstream part. They can be bought from any RV Service establishment.
You or your local dealer just have to order the pan from an Airstream dealer.
Does anyone know if the Dometic A/C is the only unit that will drain through to the holding tank. I've heard that if you put a coleman or Carrier on that the water will drain off the outside of the trailer.
I've talked to 3 different people at Camping World and got 3 different answers to the question above. They do, however, have the best price on 15,000 btu units.
I was unaware that A/S installed any AC units that actually drained condensate into the holding tank. My factory Dometic AC/Heat Pump does have a drain line that runs the condensate thru a tube that opens on the bottom of the A/S (ie no water dripping down the side of the A/S, just underneath it). At rallys, everyone's AC seems to have the same drain setup. Having the condensate drain into the holding tank has potential as in heavy humidity and certain soil condition, you wind up with a mud puddle on the roadside of the A/S below the drain. My home AC units both drain directly into the home sewer lines (with overflows to the outside) and I do like the absense of a constant wet area outside the house so common with installations draining to the outside. The downside of doing such an installation on a RV AC unit is that an AC unit produces considerable amounts of water a day and that would be filling your gray tank with otherwise perfectly clean water. Lots of state parks have electricity, but no gray water dumping at the pads, so I would want a way to valve the condensate to either the holding tank or to the outside drain. If the condensate drain line can be easily found, it could be diverted to Y-type drainline at the lavatory or sink so that it would drain into the holding tank, but not actually be connected to it (along the lines of a dishwasher connection). I sense a potential DIY project.
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
President Heart of Texas Camping Unit
WBCCI # 7548
I called Camping world to schedule a time to have a 15,000 btu Duo-Therm installed. I was told my this person that only the low profile "Penguin" would work. They said they could try to use the standard Duo-Therm Dometic, but couldn't guarntee it would match up to the drip pan. Anybody come across this ? I've put a call into Airstream and haven't gotten a respose yet.
