Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 11-07-2003, 10:44 AM   #1
camphost
camphost's Avatar
Profile:
Question air conditioner replacement '76 Ambassador
What is the recommended replacement make/model for an Armstrong air conditioner in a 29ft 1976 Ambassador? Plus any "tips" on installation? We will be installing unit ourselves. Thanks
camphost is offline   Reply With Quote
Old 11-07-2003, 11:05 AM   #2
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Camphost,
Are you sure you need to replace the Armstrong Unit? Those things are built like a tank, a lot of the time you will be better off repairing it. Run a Search on this board for "Armstrong" there is a lot of great information.
Aaron
Old 11-07-2003, 01:38 PM   #3
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
Thumbs up I did it
I replaced my a/c with a Dometic Penquin. Was not too difficult. I also got the drain pan for it. The drain pan you need to get from an AS dealer. The Penquin you can get any where.
I put some info about it on my website if your interested.
AC replacement
It was actually one of the easier jobs.
good luck!
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Air Conditioner Replacement John Sims Furnaces, Heaters, Fireplaces & Air Conditioning 22 08-22-2006 11:46 AM
Air conditioner thermostat working? nickcrowhurst Furnaces, Heaters, Fireplaces & Air Conditioning 7 03-18-2004 08:37 PM
Air Conditioner Draft w9det 2001 Safari 11 09-01-2003 11:01 AM
Air Conditioner Question/Problem??? pscottn Furnaces, Heaters, Fireplaces & Air Conditioning 6 08-23-2003 11:21 AM
Replacement air bag’s on the rear suspension? TRAPEZE Airstream Motorhome Forums 1 03-09-2003 09:42 AM
test
