Old 07-21-2019, 01:37 PM   #1
sabegirl's Avatar
1991 25' Excella
Pine Bluff , Arkansas
Air Conditioner Low Power
Our Duo Therm Air Conditioner runs fine on high but when you try to turn it down to low or medium it shut off completely and a red signal light comes on with a low power message. If you turn it back up to high it runs fine. Does anyone have a idea of what is going on? We're running it at 30 amps.
sabegirl is offline   Reply With Quote
Old 07-22-2019, 12:46 PM   #2
2015 28' Flying Cloud
Newtown , Pennsylvania
Where is this red light?
Bruce
50 amp, Awning package
2015 Ram 2500 6.7 TD, Blue Ox 1000 lb.
4 Lifeline AGM, Trimetric 2020
PD9160 converter, Prosine 1800 inverter
2x eu2000i Propane
AstroBruce is offline   Reply With Quote
Old 07-22-2019, 01:50 PM   #3
1981 31' Excella II
New Market , Alabama
I suspect you have a bad capacitor. The fan uses different ones for different speeds.
Perry
Old 07-22-2019, 01:55 PM   #4
Long Island , New York
Is your A/C 1991 OEM?
Old 07-22-2019, 03:12 PM   #5
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I experienced this on my 91 DuoTherm. Replaced caps, motor failed a few months later.
My mains voltage always remained acceptable... 120-128 volts.
Those long shaft motors are difficult to find for those specific Airstream models. A Penguin II might be in your future!
Old 07-23-2019, 07:32 AM   #6
sabegirl's Avatar
1991 25' Excella
It's a little red light on the air conditioner housing that comes on to indicates low power. It's just weird that it runs fine on high speed.
I'm not sure if its the original OEM air conditioner. We're the 2nd owner. It's pretty old though. This just started this year.
Penguin II $852.00. Ouch.
Old 07-23-2019, 07:48 AM   #7
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
The P2 is improved. I think it's worth the cost. It uses cups rather than a leaky pan. You'll also need a thermostat and air distribution box.
Add shore power chord for rear air conditioner mayco Classic Motorhomes 7 05-27-2014 05:32 AM
Air conditioner works on high but not on low ncrenshaw33 General Repair Forum 2 07-03-2013 06:14 AM
Air Conditioner tripping breaker in my house while on shore power Wgbarrbevco General Repair Forum 10 08-16-2012 06:07 PM
air conditioner won't stay on - low power TX Sister Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-26-2010 02:41 PM
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 10:43 AM
