Old 06-21-2016, 07:35 PM   #1
2009 27' FB International
Indianapolis , Indiana
Air conditioner is dripping
My Dometic air conditioner started dripping last trip when on. I have an 09 INTL 27FB. I think there is a drain hose for condensation from the unit somewhere hidden through the interior that then drips out the bottom of the trailer. My guess is somehow that is plugged. Has anybody else experienced this issue?
amckibbe is offline   Reply With Quote
Old 06-21-2016, 07:36 PM   #2
FCStreamer's Avatar
2014 30' Flying Cloud
Yes. Both my ACs dripped. A tech came out and found kinks in the drain lines. Straightened those out, no more dripping.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 06-21-2016, 07:56 PM   #3
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
There are many threads on this subject. Blocked or kinked drain hose yes is a culprit. Also a crack in the drain pan. In my case there was a leak in the union connection from the pan to the hose. It is a pressed piece of metal pipe that the hose is clamped on to. Access is sometimes possible by removing the inner AC housing to see the drainage pan etc. Another cause of a minor nature is, if there is an excessive amount of humidity in the trailer. There then will be condensation on various metal parts of the unit that will tend to drip from the unit. Condensation will be caused by an open window, vent or door. Good luck in finding the cause.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 06-28-2016, 01:22 PM   #4
la nomade's Avatar
2018 22' Sport
stanfordville , New York
mine did the same thing....had eventually to remove the pan that was full of cracks and coated it with fiberglass...no problem since...but it took some doing..removing the unit etc...good luck
la nomade is offline   Reply With Quote
Old 06-28-2016, 01:33 PM   #5
FCStreamer's Avatar
I have since found that my ACs drain only when the fan is off. When the fan is on, there appears to be some sort of resistance of vacuum being formed that prevents the ACs from draining.
So if I set the fan to Auto, the ACs work fine, but if I set the fan to HI/Med/Lo, and don't turn them off, the pan fills and they start leaking inside my AS after 3-4 hours of continuous operation.
Sigh.
Old 06-28-2016, 01:42 PM   #6
2005 30' Classic
Burlington , Ontario
I had a bad condensate leak dripping inside the trailer also.
In my case it was due to crack around the end of the plastic condensate tray where the drain hose pipe fitting is installed.
I fixed it up a few years ago just by "gooping it up" with sealant. That lasted a couple of seasons but the leak started again last year.
This time, I tried to do a slightly more thorough repair - still was able to do it working from inside the trailer and without having to remove the air conditioner.
I made an aluminum reinforcing plate to strengthen the end of the condensate tray where the draintube fitting is installed - I made it with a suitable sized hole for the fitting to go through.
I found a "JB Weld" epoxy product that specifically said it was OK for plastics including ABS and PVC, and I used this to bond the aluminum plate and hose fitting to the end of the tray.
Then as an added precaution, I covered the repair area with several coats of a commercial grade flexible sealant - called E6000 I think.
It seems to have done a good job - fingers crossed.
I think I read someplace that this is a common problem and that there is a redesigned drip tray arrangement now available, but I believe the AC unit may need to be removed to install it - I'd rather not get into that! I think if I had to go to that extent, I would buy a new AC!
Brian.
Old 06-28-2016, 02:22 PM   #7
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Our ceiling dripped badly on one trip and I found the end of the condensate hose clogged with a mud dauber nest. I poked a wire up the hose and a half gallon of water drained out.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 06-28-2016, 02:36 PM   #8
dznf0g's Avatar
Oswego , Illinois
Ditto, except I used JB weld. No leas since on any fan speed.
-Rich-
Old 06-28-2016, 03:41 PM   #9
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
I also have condensation that occasionally drips inside the trailer( no drain lines... Just drains down the side of trailer). I have a Dometic penguin, any ideas why?
Cochese is offline   Reply With Quote
Old 10-03-2018, 10:26 AM   #10
2016 25' Flying Cloud
Cedar Park , Texas
where is the condensation hose located and what kind of wire did you use?
brendakerry is offline   Reply With Quote
Old 10-04-2018, 04:53 PM   #11
ghatfield's Avatar
2006 19' Safari SE
Anacortes , Washington
Wire puller works well to clean out drain hose
I have had the same problem with our Bambi and today I removed the ADB (air distribution box) from the inside of the AC unit (11,000 BTU Penguin) and dropped the remaining interior parts of the AC so I could inspect the condensation drain system. My 2006 Bambi is equipped with an Airstream drip pan which catches condensation and routes it to the hose. I found numerous cracks in the condensation pan were it attaches to the hose and it will have to be replaced. This involves removing the exterior of the AC unit. A really great thread on this topic can be found here: http://www.airforums.com/forums/f44/...it-104778.html I will probably use the newer Dometic system that uses two "cups" to catch condensation.
I also checked the patency of the drain hose by inserting a wire puller similar to the one shown below. I used the small end and it was easy to pass it up from the wheel well to where it enters the AC unit.
Name:	wire puller.JPG
ID:	324426   Click image for larger version
Name:	drip pan is cracked.jpg
ghatfield is offline   Reply With Quote
Old 09-11-2019, 11:18 PM   #12
Oklahoma City , Oklahoma
I found cracks in my drip pan for the condensation also. I used a coat of JB plastic Weld. Did one coat and let it dry. Did another coat and put plastic mesh used for drywall in the JB Weld. One additional coat to get the mesh completely saturated with the JB weld. Just finished this so I can't say for sure if it is going to work or not but I am hopeful. Really don't want to remove the AC to replace the pan.
Americal is offline   Reply With Quote
Water dripping from heat pump Loren Furnaces, Heaters, Fireplaces & Air Conditioning 5 10-27-2015 10:02 PM
AC Unit dripping condensate Rosie39j Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-19-2006 06:44 AM
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 10:43 AM
A/C dripping Zoltan Furnaces, Heaters, Fireplaces & Air Conditioning 8 08-04-2005 10:03 PM
Penguin A/C dripping inside Janssvt Furnaces, Heaters, Fireplaces & Air Conditioning 1 09-25-2004 08:22 PM
