Old 11-15-2010, 06:15 PM   #1
1969 18' Caravel
Bee Cave , Texas
air conditioner for 1969 Caravel
I would love to have some thoughts about installing air in a trailer that does not have a/c . I just have a fan in the ceiling and really do not want to give that up. Is it true that you cannot install the a/c where the fan is anyway ? Has anyone used a portable a/c in a small trailer like mine ? Thanks.
Beecavetx is offline   Reply With Quote
Old 11-15-2010, 06:35 PM   #2
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
We added A/C to our 69 tradewind. I emailed Andy at Inland RV who had the location inside the ceiling for the wire there down to the inch in one of his books measured from Bow #1 (the first support after the end cap ends). Was a very easy install.... See the thread:
http://www.airforums.com/forums/f427...day-35176.html
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 11-15-2010, 06:57 PM   #3
1969 18' Caravel
Bee Cave , Texas
Our Caravel has only one roof opening which is where the fan is. I thought that Andy had stated that you cannot use this opening for an a/c unit. Do you have more than one roof opening ?
Old 11-15-2010, 07:34 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The opening for the AC is not made if the trailer does not come with an AC. A hole needs to be made if you want to install an AC.
Richard
Old 11-15-2010, 07:53 PM   #5
goransons's Avatar
1963 22' Safari
What Richard said, if you look at the link I posted there you'll see me marking for the location. Airstream designed the trailer to support (balance wise) A/C in a particular location and prewired inside the ceiling in 69 for that so it could be cut open at a later date (such as a dealer add on). It does not go in a vent location. Cutting was a piece of cake, just had to add a few braces to span the opening.
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 11-15-2010, 07:58 PM   #6
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Not a problem
Here is the one I mounted. It was no problem and the unit is great. Portable units are a pain to use and I don't feel like they do a good job...(here in Texas.) Low profiles are still available and I recommend one instead of the big units...they look all wrong on a small Caravel
caravel
1969 Air Conditioner Change out 1969Lloyd Furnaces, Heaters, Fireplaces & Air Conditioning 15 06-21-2015 04:18 PM
Adding Air to 1969 Caravel-Help Lone Rangerette 1969-1971 Caravel 15 07-09-2006 10:32 AM
Add air to 1969 Caravel-Help Lone Rangerette Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-27-2006 09:41 PM
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 10:43 AM
