Old 06-30-2003, 10:19 AM   #1
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
Lightbulb Air Conditioner FAQ's
Great idea isn't it!
Someone should write up a document. Otherwise, we'll keep answering the same questions every few weeks. Any takers?
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 06-30-2003, 10:44 AM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Sort of related to this thread. Here is a comment I found on the Camping World website. Looks like someone is running their AC off of an inverter while driving. I'll bet his alternator is working overtime. I hope he is carrying a spare.
Customer Reviews
479 out of 535 people found this review helpful.
Mach 3 PS - May 12, 2001
Reviewer: Lere Vormelker from Milford, NH
Review: I purchased the high efficiency Mach 3 with the specific intent of using a ProSign 1800 watt inverter to power the AC while driving. The low power draw of the Mach 3 has effectively cooled my camper while eliminating the need to run the generator while traveling. Great product combination Mach 3 and ProSign 1800 Regards Lee Vormelker
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 06-30-2003, 10:48 AM   #3
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
that is a good idea if you dont have a gen set. but the mach 3 ps is not a ac that airstream is using. no drip pan. and i will not ruin my as exterior . lol
al
wb13798 is offline   Reply With Quote
Old 06-30-2003, 10:51 AM   #4
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
Does anyone have a picture of these drip pans?? Mine drips down the side. I cannot seem to find tubing for a drip pan either. Looks like mine must have come with maybe an Armstrong unit and someone changed it out to a Coleman.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 06-30-2003, 10:53 AM   #5
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
That's a high-efficiency unit, but it still draws at least 10A @ 120VAC. That' means 100+ from the alternator. I'd definitely want a 2nd alternator for that. And even at that, when the engine's idling, the batteries have to take up the slack.
He's either got the inverter mounted under the hood (where it's hot) or is having to run HUGE 12V cables. I'll bet it's 30+ feet from my alternator back to the compartment under the couch where an inverter would be.
Maurice
Old 06-30-2003, 10:56 AM   #6
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
It is probably in a MH, but still, the amperage draw. You'd need welding cables no matter how far away it was, and John HD to wire that sucker.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 06-30-2003, 12:17 PM   #7
1972 25' Tradewind
Rogers , Arkansas
Does anyone know whether all of the Armstrong Bay Breeze units had multiple speed fans? Several of the threads suggest that there are high and low speed settings. Mine is hooked to a standard thermostat and only operates at gale force.
pepper48 is offline   Reply With Quote
Air conditioner thermostat working? nickcrowhurst Furnaces, Heaters, Fireplaces & Air Conditioning 7 03-18-2004 07:37 PM
Air Conditioner Draft w9det 2001 Safari 11 09-01-2003 10:01 AM
Air Conditioner Question/Problem??? pscottn Furnaces, Heaters, Fireplaces & Air Conditioning 6 08-23-2003 10:21 AM
Heater and Air Conditioner Jeb Airstream Motorhome Forums 2 10-22-2002 07:45 AM
