Old 11-12-2012, 01:19 PM   #1
2013 25' Flying Cloud
sussex , New Jersey
Air Conditioner fan speed question?
2008 safari ac fan speed is to high even set on low. Called ac manufacturer and they say it is because of heat pump (which we don't use). Anyone else having same issue?
bmark is offline   Reply With Quote
Old 11-12-2012, 02:24 PM   #2
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
We had a Dometic Penguin 15,000 btu heat pump installed last summer at Jackson Center. It does blow loud and hard on low fan speed as compared to our old 11,000 btu air conditioner. Found out last week that the heat pump cycles off for defrost every 25 minutes when outside temperature drops below 42 F. I thought the heat pump was failing when it shifted into defrost mode the first time.
I can live with the loud fan, the performance of the AC and Heat Pump has been wonderful as compared to the performance of the old AC and keeping up with propane for the furnace.
Bud
Ridgerunner3 is offline   Reply With Quote
Advice Needed: Duo Therm Air Conditioner & Heat Pump BKBroiler67 Furnaces, Heaters, Fireplaces & Air Conditioning 19 07-22-2015 05:40 AM
Furnace Fan Rattling tmarquis Furnaces, Heaters, Fireplaces & Air Conditioning 1 08-29-2011 05:32 AM
Can you run both Air Conditioners with the Genset? Keyair Classic Motorhomes 4 08-26-2011 05:32 PM
Air conditioner went south... Bing-Bing Furnaces, Heaters, Fireplaces & Air Conditioning 12 06-16-2011 06:14 PM
Blasphemous question woytovich General Repair Forum 15 04-09-2011 08:36 AM
