Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 06-25-2002, 08:44 AM   #1
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Send a message via AIM to jcanavera
Air conditioner drain
We have just passed our first year anniversary with the Safari. Since its a little more difficult to get to the roof, I haven't pulled the shroud off the Duo-Therm Penguin unit. Does the water drain stay pretty free of debris or is this something that requires annual maintenance?
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.,'03 GMC Savana 2500,'08 Vespa GTS 250
jcanavera is online now   Reply With Quote
Old 06-29-2002, 11:26 AM   #2
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
My extreme curiosity would be screaming at me to at least take a peek under the hood. You might want to clean the dust and bugs off the coils and shopvac the detritus ($5 word for loose matter) that you may find in the housing. Also check any tubing insulation and wiring connections. Just like a homes HVAC system, it should be inspected annually. Preventive Maintenance never hurts. Failure to check always does.
You might also want to pull your A/C user manual and see what it recommends and the frequency.
Why do air condioners never break in the winter and heaters never break in the summer? One of lifes mysteries.
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 07-01-2002, 04:44 PM   #3
jcanavera
jcanavera's Avatar
Fenton , Missouri
Images: 143
Bobby,
I'm usually pro-active in this area. It's just a matter of getting a ladder up on that curved roof. Once I do this, I will pop open the top. I am quite curious to see what the Penguin looks like inside.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-10-2002, 01:52 AM   #4
53flyingcloud
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
Savannah , Missouri
Send a message via ICQ to 53flyingcloud Send a message via Yahoo to 53flyingcloud
A/C Drain
Just a curious question, which seems to fit this thread.
Does anyone have first hand knowledge if A/S has ever made a trailer in recent years(from 1980 onward) without a A/C drain tube? I, for the life of me, can't imagine this to be BUT...
This was brought to my attention recently that, this might have happened.
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Air conditioner thermostat working? nickcrowhurst Furnaces, Heaters, Fireplaces & Air Conditioning 7 03-18-2004 07:37 PM
Air Conditioner Draft w9det 2001 Safari 11 09-01-2003 10:01 AM
Air Conditioner Question/Problem??? pscottn Furnaces, Heaters, Fireplaces & Air Conditioning 6 08-23-2003 10:21 AM
For Sale 13,500 BTU Air Conditioner GoldFever Parts Archive 4 08-09-2003 09:11 PM
Heater and Air Conditioner Jeb Airstream Motorhome Forums 2 10-22-2002 07:45 AM
Forums Directory
