Old 02-12-2019, 03:42 PM   #1
2017 27' Tommy Bahama
* , Texas
Air Conditioner BTU rating
We have a 2017 27FB with 50-amp and factory-installed dual air conditioners (ACís). I have the following questions regarding the ACís:
(1) Are the both the ACís rated at 15000 BTU units,
OR is one rated at 13500 BTU, and the other at 15000 BTU?
(2) IF it is one of each, is there a quick and easy way to identify the 15K and the 13.5K unit without going on the roof for visual inspection?
The documentation I have favors the second choice. However, I haven't found documentation as to which is which.
I look forward to hearing opinions from the Forum.
J-squared is offline   Reply With Quote
Old 02-12-2019, 04:57 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Generally, the one in the bedroom is 13,500.
Old 02-12-2019, 05:37 PM   #3
2018 28' International
Fayetteville , Georgia
Bedroom A/C is the 13,500
brick
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 03-19-2019, 05:48 PM   #4
Ditter's Avatar
1994 30' Excella
Franklin , Ohio
My unit is older but if you remove the air filter on curb side thereís a tag that has btu rattling along with serial and model may need flash light to read
Ditter is online now   Reply With Quote
Single 15,000 BTU AC insufficient; 18,000 BTU? high vs. low profile fotoman1527 Furnaces, Heaters, Fireplaces & Air Conditioning 15 09-12-2018 07:02 AM
13500 BTU vs. 15000 BTU Eddie25 Furnaces, Heaters, Fireplaces & Air Conditioning 14 12-20-2013 11:50 PM
HOT IN TEXAS!!!! Upgrade a 13,000 BTU to a 15,000 BTU? Does it help? bowhead13 Furnaces, Heaters, Fireplaces & Air Conditioning 47 07-19-2013 12:02 PM
15K BTU Brisk Air vs. 15K BTU Penguin adwriter73 Furnaces, Heaters, Fireplaces & Air Conditioning 9 05-23-2011 10:32 AM
