Old 10-08-2011, 10:49 AM   #1
Bettye's Avatar
2010 25' FB International
Mobile , Alabama
Images: 18
Air Conditioner
We need to do some general maintenance of our A/C, mainly clean the coils. It's a Briskair Duotherm by Dometic. Any suggestions?
Bettye & Harry
WBCCI #10360
Member Southeastern Camping Unit
Bettye is offline   Reply With Quote
Old 10-08-2011, 12:20 PM   #2
dznf0g's Avatar
Oswego , Illinois
without any specific complaint, just remove the cover and clean everything well, especially the condenser coils. I think, if it's an old unit, there are oil points for the motor shaft. Don't overdo it, just a few drops per end.
Check over the wiring for rodent, etc damage and see that the insulation is not cracked, etc.
I think that's about it.
Old 10-08-2011, 12:52 PM   #3
1974 Argosy 20
Kooskia , Idaho
Compressed air is best to clean the coils. Messy, but effective.
Old 10-08-2011, 01:10 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
You should buy COIL CLEANER from any heating and cooling supply house. Remove the cover if possible and spray the cleaner on then rinse with water.
If you have a weed sprayer that will work for the water as you do not want to flood the evaporator coils inside and make a mess.
Force of air or water is not recommended. Try and apply everything straight on to the coils as this will get the cleaner in farther.
2004 Excursion 4x4
Advice Needed: Duo Therm Air Conditioner & Heat Pump BKBroiler67 Furnaces, Heaters, Fireplaces & Air Conditioning 19 07-22-2015 05:40 AM
Air conditioner cover havec1 Roof Vents, Skylights & Fans 4 08-12-2011 09:35 AM
need air conditioner ally 1966 Overlander 2 07-02-2011 09:54 PM
Air conditioner shroud repair for 1974 Sovereign Shamock Furnaces, Heaters, Fireplaces & Air Conditioning 3 05-09-2011 06:30 PM
Air conditioner wattage ubuckster Furnaces, Heaters, Fireplaces & Air Conditioning 12 02-25-2011 12:53 PM
