Old 07-06-2015, 03:02 PM   #1
1967 26' Overlander
Amity , Arkansas
air conditioner
My ac fan motor started seizing. I sprayed upper bearing with lubricant and freed it up some. I wanted to take the motor off to rebuild it , but can't get the bottom fan blade off. I have tried several lubricants with no success. Is it threaded? I took out the set screw. It is an Armstrong ac on a 1967 overlander. A fine ac up to now
Johngould is offline   Reply With Quote
Old 07-06-2015, 09:32 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Well, this may be a 'Dear John' note from your 'Armstrong'... Pictures would help a lot.
Usually fans are NOT threaded.. would be surprised.
So, one 'option' if you can't pull it off would be to apply some 'heat'.. carefully... If you are not proficient with a torch, a word of warning... heat the part.. do not melt it.
Can you get a 'puller' on it? Get some 'S-OK' and some PB Blaster.. those are good 'solvents' and may help things release.
Again.. a picture(s) would help..
Good luck!
Peace and Blessings..
Channing
WBCCI# 30676
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 10:43 AM
Air conditioner drain jcanavera Furnaces, Heaters, Fireplaces & Air Conditioning 3 07-10-2002 01:52 AM
Air conditioner compressor rdm Mechanics Corner - Engines, Transmission & More... 2 05-13-2002 06:54 AM
