Old 08-19-2010, 09:31 PM   #15
werpknarly's Avatar
1980 31' International
there , Wisconsin
yes, if i remember.. but will check.. runs ok in fan mode.. it trips when the compressor starts up... and it does run for a short bit till the breaker trips
werpknarly is offline   Reply With Quote
Old 08-19-2010, 10:06 PM   #16
1977 31' Excella 500
plano , Texas
Turn off all of the breakers other than the AC and try. If your AC is not tripping your 20 amp line to it, you have an additional load in the trailer. I have found that diagnosing an electrical problem is far easier in an air-conditioned trailer.
-t
tschat is offline   Reply With Quote
Old 08-19-2010, 10:31 PM   #17
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
The new A/C on my 78 31' won't start without a good 30 amps. Turns off itself off when there isn't enough power like when I turn on the vacuum. (Oh I found a filter for the vac at Grainger).
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 08-20-2010, 06:58 AM   #18
Crusty's Avatar
1992 34' Excella
It's likely that there's crud inside the compressor, preventing the rotor from spinning up. You can try this ac repairman's trick and maybe get it running again. On the compressor (with the power disconnected of course) swap the start and run wires at the feed through connectors. Turn the power on, but keep the cooling control switched to off. Then using an insulated handle screwdriver, jog the compressor contactor a few times for a couple of seconds. This will try to make the rotor spin backwards and it may dislodge the crud which is preventing the rotor from spinning up. Kill the power again and put the wires back where they are supposed to be, turn on power and give it a try.
This is a last ditch approach and even if it works it signals the end of life for your ac unit.
If you don't understand these instructions and how to perform them then your electrical knowledge is probably not sufficient to pull this operation off and attempting it will be quite dangerous for you and you should call a buddy for help who does understand the procedure.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 08-20-2010, 07:25 AM   #19
HowieE's Avatar
Princeton , New Jersey
Images: 12
Before he tries this please explain to me how swapping the leads on a 120 AC motor will cause it to run in the other direction.
If the unit starts for a FEW MINUTES and then fails while drawing 25 plus amps I would suspect one of the windings in the one of the motors has shorted and thus the high current draw. It seams you have a current meter. If you can get into the AC read the current on the fan motor and then disconnect the fan motor and read the running current on the compressor. Running the compressor for a minute without the fan won't be a problem.
Post those current readings.
2004 Excursion 4x4
Old 08-20-2010, 07:35 AM   #20
Crusty's Avatar
1992 34' Excella
The start winding becomes the run winding and the run winding becomes the start winding - net effect is that the rotor spins the other direction.
Crusty
Lake Travis, TX
"Rancho Deluxe"
Old 08-20-2010, 07:48 AM   #21
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
You could also come close to this test without disconnecting things by running fan-only and checking the current, then observe the change in current when you turn it to cool. Adding vs. subtracting, but you don't have to disconnect the fan motor if that's inconvenient.
Old 08-20-2010, 08:18 AM   #22
HowieE's Avatar
Images: 12
My reason for separating them is to insure they are each running with max voltage available. If the test is run while they are connected have a voltmeter plugged in to make sure there is not a significant voltage drop and thus a current rise.
2004 Excursion 4x4
Old 08-20-2010, 09:59 AM   #23
werpknarly's Avatar
there , Wisconsin
not really "few minutes"... really about 5-10 seconds, just long enough to heat up and trip the breaker. Power Supply OK, No other loads in trailer are the issue, before i spend to much money (new shroud is 230+160 shipping ) what are replacement options?
Old 08-20-2010, 10:03 AM   #24
Wise Elder
Jammer's Avatar
2010 30' Classic
Probably a shorted winding and time for a new compressor. There's life after compressor failure, you don't need to scrap the whole A/C. Continuing to fiddle with it runs the risk of a more catastrophic failure and a shower of debris through the refrigerant lines which would complicate replacement, so don't do it.
The locked rotor current should be well in excess of 30 amps so I doubt if the reversing trick will help. However, for posterity, and the edification of all present, I offer herewith an explanation of why it does what it does.
A rigorous explanation requires calculus. In a capacitive circuit, current flow is proportional to the derivative (over time) of the voltage. Since the applied voltage is sinusoidal, the current flow through a capacitively coupled winding will lag by pi/2. Details become murky and require more calculus to illustrate rigorously because the circuit isn't purely capacitive, and in an inductor the current is proportional to the integral of the voltage, but that's the simple version.
Anyway, the delay, produced by the capacitive nature of the circuit, is what produces the twist in the magnetic field produced by the stator. Reversing the start and run windings delivers the delayed current to the run rather than the start so the twist goes the other way.
Old 08-20-2010, 11:20 AM   #25
Crusty's Avatar
1992 34' Excella
The reversing trick often does work and there have been many homeowners that have paid the price for a "new" compressor when in fact they only got the reversing trick plus a can of spray paint to make their old compressor look new.
I learned about this trick while talking with an ethical ac guy about unethical repairmen in the HVAC business, and I've used it successfully in the past to delay the replacement of my own compressor.
Crusty
Lake Travis, TX
"Rancho Deluxe"
AMPS 20? 30? 50? Which One Do I Want? Frank&Mike Batteries, Univolts, Converters & Inverters 7 06-24-2009 07:35 PM
Air con Installation Dannear Furnaces, Heaters, Fireplaces & Air Conditioning 3 05-23-2006 03:04 PM
Overlander CAD drawing Cornfred Interior Restoration Forum 8 09-12-2005 06:24 PM
Posting Drawing from MS Paint...too big jaco Forum Admin, News and Member Account Info 2 02-08-2004 09:30 PM
