Old 05-07-2015, 09:07 PM   #1
Napking
Skee75's Avatar
2015 30' International
Plymouth , Minnesota
Air con confusion
Hello,
I have two air con units, and can't figure out why the unit in our bedroom does not send out cool air. I'm assuming the front and back unit are not interlinked at the thermostat. If I turn on zone 1 to auto or cool, the cool air comes out of all the vents. If I turn on zone 2 to auto or cool, ambient air comes out of the rear vents. Any ideas why the back unit is not pumping cool air? Also, the rear zone 2 unit has an option to choose heat pump. Zone 1 does not give me this option.. So weird.
Skee75 is offline   Reply With Quote
Old 05-26-2015, 12:21 PM   #2
2014 27' FB International
Nebo , North Carolina
Try turning on back unit first. It may be front unit has brought down the temp to the setting on the back unit so the compressor will not start until temp is above thermostat setting. Good luck.
JimGaskill is offline   Reply With Quote
Old 05-26-2015, 01:39 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Yes only turn on the rear unit. Set the thermostat very low and wait 3 to 5 minutes. if the compressor has not come on in that time you have a problem.
If the fan is running the unit has power. If the compressor did not come on it could be in order of cost. bad thermostat, bad control board in the unit, bad starter capacitor or dead compressor. If you take it for service make them check those items in order and not just say you need a new unit.
2004 Excursion 4x4
Old 05-26-2015, 03:11 PM   #4
Plasma800's Avatar
houston , Texas
Awning Pack Install? Dealer or JC?
I wouldn't mind having the awning package installed. Is something a dealer can do, or something you should really let JC do? Not sure how involved the install is?
'15 27fb Signature
'12 Chevy 2500HD Gasser
Plasma800 is offline   Reply With Quote
Old 06-07-2015, 08:00 PM   #5
Napking
Skee75's Avatar
I guess I need to take it in. The bedroom A/C still does not blow cold. The compressor starts, but no chilled air..Argghh. I'm in the Lacrosse Wisconsin area. Anyone have a dealer suggestion?
Old 06-07-2015, 08:03 PM   #6
Gainesville , Florida
I would take it back to the dealer I bought it from. Jim
Old 06-07-2015, 09:25 PM   #7
lewster's Avatar
Naples, FL , Hood River, OR
If your compressor is active and you're not getting cold air (18-22ļF below the ambient room temperature measured AT THE AIR RETURN GRILL, then your A/C has lost it's refrigerant and must be replaced.
Dometic units carry a factory 2 or 3 year warranty, and any Airstream dealer can replace the unit under either the Dometic warranty or the Airstream warranty. I would be wary of having any other Dometic warranty center deal with the replacement, as they will not be familiar with the nuances of working on an Airstream.
Old 06-08-2015, 08:37 PM   #8
Napking
Skee75's Avatar
Bummer. I will contact my dealer for help. Thanks
Old 07-15-2015, 11:32 AM   #9
Napking
Skee75's Avatar
Quick update: The unit was replaced under warranty this AM. We nice and cool!
1988 345 Classic Dash Air Con nellie1960 Classic Motorhomes 23 08-10-2014 06:12 PM
Interstate 3500 pro and con TY PECK General Motorhome Topics 1 08-24-2010 07:58 PM
'09 Air Con Condensate Problem T Stephens Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-22-2010 11:51 AM
air con drawing 30 amps... werpknarly Furnaces, Heaters, Fireplaces & Air Conditioning 24 08-20-2010 11:20 AM
Air con Installation Dannear Furnaces, Heaters, Fireplaces & Air Conditioning 3 05-23-2006 03:04 PM
