Old 09-23-2011, 11:58 PM   #1
Rivet Dude
1972 21' Globetrotter
1987 34' Excella
yep, still on the road , On The Road
After Market Drip Pan
I know, this has been talked over.
But, I was wondering, since I have received the new coleman polar cub 9200 Btu unit, installed, and it does drip alot. Has anybody had any success with a after market drip pan that will tie in to the convenient hose I found between the inner and outer shells. The "drip pan" that came with the unit, has at least 40 holes in it. Luckily, it does let the water drip through. All over the street side of the AS. Somebody must have come up with a more elegant solution than what I have found online so far.
I would appreciate being pointed to the solution.
Oh, 1972 globetrotter, 21'. Almost done with a redo. Pics soon.
AirJeff
airjeff is offline   Reply With Quote
Old 09-24-2011, 04:11 AM   #2
AirJeff
No drip pan exists for your AC.
The reason you see very little water is because of the low cooling capacity, of your AC.
In California, a 15,000 BTU AC is used almost 100 percent of the time.
Andy Rogozinski
Inland RV Center
Corona, CA
I was afraid of the belly pan Dingo Girl 1966-68 Caravel 26 10-05-2016 03:27 PM
drip drip drip kepko Sinks, Showers & Toilets 3 09-17-2011 03:36 PM
AC pan replacement A W Warn Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-25-2011 12:03 AM
Bumper, Belly Pan and Banana Wrap Repair DKAir Exterior Restoration Forum 0 06-15-2011 05:51 PM
Dent in water tank galvanized pan safariuser Belly Pans & Banana Wraps 1 02-26-2011 05:37 PM
