Old 07-21-2011, 05:20 PM   #15
casa3805's Avatar
Corpus Christi , Texas
Images: 41
Originally Posted by overlander63 View Post
A furnace was standard equipment in 1984, and a catalytic heater was not. I think the cat heater was possibly a dealer installed option, or was installed to replace a furnace that was removed. The furnace should have been a Suburban, and the usual mounting position was inside the cabinet that now has the cat heater, on the floor.
At the obvious risk of showing my total ignorance, I got the manual,read thru the entire thing and found one (1) mention of a furnace. It was on the 12 volt interior circuit page. And it showed it exactly where you said it would be Overlander63. Then I lifted the cabinet door and eureka. A suburban furnace. Vent ducts need some patching and I have propane disconnected as we do other work, so I have no idea if it will fire. But that just made so many things click. Like why is there a thermostat over the bed? What are the exhaust holes right beside the door for? How dumb can I be? Nobody answer that, it was rhetorical!! (Insert very heavy sigh here_____) So now that I know this, I still like the thread concepts of having a heat pump and a furnace.
Unreal...
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
casa3805 is offline   Reply With Quote
Old 07-21-2011, 05:47 PM   #16
Airstream Rescue
rptradewind's Avatar
1948 22' Liner
1966 20' Globetrotter
Wimberley , Texas
Does anyone know of a good substitute for the Penquin Duo Therm airconditioner now that Carrier is no longer in the rv airconditioner business? I don't know of any other brands in which you are able to drain condensate through a drain tube and not have it just run out on the roof.
We are presently sitting on the paddock at Jackson Center in our 20 foot Globetrotter with a newer 13,500 Btu Penquin that is not keeping us confortable. sorry to intrude on your thread.
rptradewind is offline   Reply With Quote
Old 07-21-2011, 06:53 PM   #17
dznf0g's Avatar
Oswego , Illinois
I think we all may be over-expecting the A/C thing right now, with this unusual heat thing. (Southwesterners need not roar in, I know this is normal for you)
Heck, my house A/C is running almost full time (21 hrs 53 minutes yesterday) and slowly loses ground all day...up to 76* by sundown. These things are sized for the "typical" weather and not one ounce more.
Just food for thought before you spend buku bucks for something that might not happen again for a decade. (AGAIN, southwesterners need not scream out) Of course if health is an issue, you gotta do what you gotta do.
Old 11-29-2011, 04:53 PM   #18
1971 27' Overlander
I have a similar need, a new A/C with a heat pump. I already have replaced my furnace in my 1971 Overlander. Looking at the Dometic products, it appears that the two main options are either the Brisk-Air (not low profile) and the Penguin (Low-profile). Is one model more reliable than the other model? Should I go for the model with electronic thermostat knowing that I have a separate thermostat for the furnace? Any feedback is appreciated. Thanks
lmassa is offline   Reply With Quote
Old 07-22-2015, 03:37 AM   #19
Toomuchfun
kcrockett's Avatar
2005 19' Safari
2005 30' Classic
Cincinnati , Ohio
I have the same question can I install a Brisk in place of my Penquin and hook up to my electronic thermostat?
kcrockett is offline   Reply With Quote
Old 07-22-2015, 05:40 AM   #20
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome Aboard....
I would opt for an AC with HP also, it does come in handy on those cool mtn. mornings.
IMHO...a 15k btu unit may be a bit much for your narrow body 24 TW.
An 11k does just fine on our 25 Classic.
dometic, heat pump, duotherm
Top air Pump Froze up, cooked the belt John H. Mechanics Corner - Engines, Transmission & More... 16 07-14-2011 07:53 PM
need air conditioner ally 1966 Overlander 2 07-02-2011 09:54 PM
Considering a '67 Overlander, Advice Needed hlo Buyer Guidelines 3 06-16-2011 01:56 PM
Advice needed - Cutting new AC in '64... robwok Furnaces, Heaters, Fireplaces & Air Conditioning 4 05-26-2011 11:31 AM
Air conditioner shroud repair for 1974 Sovereign Shamock Furnaces, Heaters, Fireplaces & Air Conditioning 3 05-09-2011 06:30 PM
