Old 06-23-2009, 10:07 AM   #1
1977 Argosy Minuet 6.0 Metre
SPOTSYLVANIA , Virginia
Adding an AC unit advice
Looking at buying a 74 safari that has no AC unit. The trailer is actually roughed inn for an AC unit from the factory or not? I understand it will fit in the rear 14 X 14 fan opening? Tell me something folks-lol
vcu70 is offline   Reply With Quote
Old 06-23-2009, 10:26 AM   #2
The AC wiring is within the shell.
If you buy the trailer, make another post and I will look up the exact location of those wires, and post it for you.
Old 06-23-2009, 07:21 PM   #3
will it fit in the fan vent hole? If it will, I'm sure I can install myself
Old 06-23-2009, 07:51 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Actually there is a frame already in place for it so you don't have to use the vent, also IIRC prewired and has the necessary drip tube in there too.
Once you get the unit and have the serial number Andy will be able to provide you with the exact location of the opening.
Aaron
WBCCI #XXXX AIR #2495
Old 06-23-2009, 08:35 PM   #5
2006 16' International CCD
Minneapolis , Minnesota
I'm planning to install a Carrier Low Profile AC on my '62 Overlander. Well, not me. But I want to have it done. It looks like the wiring is already there on the center vent in the kitchen. I'm also wondering if they'll have to cut the hole bigger or if they will be able to use the same opening...
WithChild is offline   Reply With Quote
Old 06-23-2009, 08:50 PM   #6
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
It is easy to cut the hole, measure a couple times, cut a small hole, confirm things then enlarge to the 14"x14" opening. The wire is usually taped or coiled up inside the ceiling and the location was figured by airstream to correctly balance the added weight. Post what you get, Andy gave me measurements on our 69 tradewind and the wire was within an inch of his measurement inside the ceiling coiled up and taped to the skin. The other end of that wire should be near, behind or in the circuit breaker area but not hooked up.
On the 62, I don't think there was wiring installed for a/c at least there wasn't on our 63. The power up there might handle it, but you'd want to check what all is on that circuit and figure your wire guage etc. It really isn't that difficult to fish wires depending on where you're ending up putting it, but I'd confirm what the correct location is.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Pensacola Unit vs. Big Bend Tallahasse Unit gypsymoth WBCCI Forum 23 04-07-2013 11:19 AM
Adding 2nd AC Unit in the bedroom? TxToaster Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-12-2009 06:31 PM
Adding Xantrex Panel and Converter in 1973 unit - Have Questions malconium Batteries, Univolts, Converters & Inverters 8 07-10-2008 11:13 AM
shopping for a unit to join at unit rallies GoNomad WBCCI Rallies & Events 35 11-30-2006 03:01 PM
New Unit Pre-Delivery Inspection Advice tomriley 2001 - 2005 Classic 6 02-23-2005 08:40 PM
