Originally Posted by air66stream
Well, if anyone is still following this thread, I do have the A/C unit installed now and working fine. When I get a chance, I will post some pics of the A/C install. Now I just need to know the best thing to do for the breaker box. Since the unit came without A/C, the breaker box only has two breakers. Am I right in assumung that I will have to install a larger breaker box to add one or two more breakers? (I also plan to add a microwave oven). Any advice is greatly appreciated. TomE
A larger breaker box is in order.
You should have 3 20 amp breakers and one 30 amp breaker.
The 30 amp is the master. One 20 amp is for the left side of the trailer. Another 20 amp is for the right side of the trailer.
The third 20 amp, is for the AC unit.
By the way, if you didn't already discover it, the AC wire is behind the breaker panel.
The other end of that wire, is about 18 to 20 inches, in the roof, rearward of the curtition, which is the divider between the galley and the bedroom.
