Old 08-22-2015, 10:21 PM   #1
kstewart23's Avatar
2011 27 FB International
San Antonio , Texas
Adding AC
Does anyone know about how much it would cost for AS to add a second AC to our 2011 International? One AC just doesn't seem to cut it in the South during the summer.
kstewart23 is offline   Reply With Quote
Old 08-22-2015, 10:24 PM   #2
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Need to call them. Probably just as few thousand.
kscherzi is online now   Reply With Quote
Old 08-22-2015, 10:50 PM   #3
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
Another option is Timeless Travel Trailers in Arvada, CO. When I discussed this with them they would have put the 2nd AC unit in on a separate 20A circuit with external receptacle that we could have plugged into the 110 circuit usually available or into a separate breakout box fed from the 50A power circuit providing one 30A and one 20A. So when needed we would have just plugged it in. There was no need to upgrade the whole trailer to 50A.
2012FB is offline   Reply With Quote
Old 08-24-2015, 10:14 AM   #4
kstewart23's Avatar
San Antonio , Texas
So if I was to add a second AC unit would that cause my 30 amp as to become a 50 amp as?
Old 08-24-2015, 11:45 AM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
No.. but you could only run ONE of the AC's at a time..
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-24-2015, 04:36 PM   #6
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
If you added the 2nd A/C as 2012FB noted, the second A/C would be on a separate circuit that plugged into the pedestal. You could then run both A/C's. If you only wanted to run one, don't plug in the other. I have seen this done with motor homes.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Winterizing-Adding Antifreeze JaceBeck Winterizing, Storage, Carports & Covers 13 09-25-2003 04:45 PM
Adding a second battery... drboyd Electrical - Systems, Generators, Batteries & Solar 3 07-28-2003 12:45 PM
Adding charger where no charger has gone before Jabba Electrical - Systems, Generators, Batteries & Solar 4 03-08-2003 09:39 AM
Adding a picture to a post wallybyam Our Community 5 03-03-2003 07:29 PM
