[QUOTE=TxToaster;708359]We are looking at the possibility of adding a 2nd AC unit. Has anyone had any success adding a unit in place of the rear roof vent fan? I have read through several threads on this topic, but my searches couldn't find one specifically related to abandoning the vent fan and using the pre-existing hole in through the roof.
Related questions:
Is reinforcement required in this area - such as the L-channel aluminum frame technique described on other threads?
Absolute metal framing must be installed as well as properly.
Any success in using one of the vent fan's wire as a pull line to get the appropriate wiring up to the ceiling?
That's impossible to do since the wiring in the ceiling is in a cable.
While the condensation can drain off the roof, I would much rather fish, or pull a condensation tube through the wall if that is possible - then tie it to the sub roof drain pan like is done in the front of the trailer. Anyone have any success with this approach?
A drain line can be fished into the rooflocker, then into a closet, and then thru the floor and underbelly. Or use a Carrier AC and you do not need a drain tube.
Did you install a separate breaker box, or just run a separate heavy duty 110 cord from a junction box which ties in to the AC power feed?
Simply add another 30 amp cable and breaker box, for the second AC. Saves time, and money. You can fish the wire thru the shell enough to get into a rooflocker. from there, thru a closet, where you can mount the breaker box.Typical campgrounds have two 30 amp outlets.
Hope these questions make sense.
Thanks, in advance.
Hope these answers help your decisions.
