Old 10-22-2019, 11:50 AM   #1
1975 Argosy 20
Baltimore , Maryland
Add A/C in 1976 Argosy Minuet 20'
Hello, I just purchased a Argosy 20' Minuet and would like to add A/C to it. Any direction would be greatly appreciated!
npm5031 is offline   Reply With Quote
Old 10-22-2019, 07:56 PM   #2
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Check out Smokeless Joe's split A/C on his Argosy trailer.
Cheers
Sidekick Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 10-22-2019, 09:43 PM   #3
Argosy man's Avatar
1973 Argosy 22
Carleton , Michigan
If you are looking to add a roof A/C unit-
I added one in our 73 Argosy. We did it after going to a rally with 95 degree heat and no shade- felt like we were boiling in a soup can
Your trailer should be prewired for it as ours was- somebody more knowledgable than me on this forum should know the exact locations of the wires in the ceiling and where to cut the hole in the ceiling. Or look at the location on another trailer like yours. You will need to cut some curved supports (I did mine out of 2x4 pieces); to support the curve in the roof. They will slide between the inner and outer roof before bolting down the unit.
You will have to add another circuit breaker to your box. The other end of the A/C wiring should be inside the wall behind your circuit breaker box. You will need to unscrew your box from the wall; cut a hole in the wall just big enough for your hand (that will be covered up when you put the box back), reach in the hole and pull your wires out.
Definitely worth the time and effort- you will need a freind to help you lift the unit onto the roof; but other than that, pretty easy.
Have fun,
Shawn
Argosy man is offline   Reply With Quote
Awning and/or Air Conditioner for 1976 Argosy Minuet npm5031 Airstream Classifieds 0 10-22-2019 11:47 AM
1976 Argosy Minuet for parts hd1462 Airstream Classifieds 1 06-23-2019 07:35 AM
1976 Argosy Minuet Alex Csank Airstream Registry Discussions 0 07-17-2014 11:48 AM
1978 Argosy Minuet 6.0 Metre :: 1978 Argosy by Airstream Minuet 6.0 Metre overlander64 Airstream Registry Discussions 0 08-19-2011 09:30 AM
