Old 05-22-2013, 05:54 PM   #1
GAStreamin's Avatar
2012 25' Flying Cloud
Moultrie , Georgia
AC with wall thermostat or not?
Which is better AC with thermostat on the wall or one you turn on and off at the unit?
GAStreamin is offline   Reply With Quote
Old 05-22-2013, 06:14 PM   #2
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
I just bought a 13.5k Dometic Penguin II with heat strip and thermostat. The thermostat will also tie into my furnace down the road. The thermostat will allow you to set a max/min temp to keep the TT cool/warm while you are away. And would also save you having to get up in the middle of the night to manually turn on/off the a/c or heat.
arktos55343 is offline   Reply With Quote
Old 05-22-2013, 06:14 PM   #3
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Whichever one keeps you consistently cool with the least amount of noise and energy consumption.
:not-a-helpful-answer:sorry:
Old 05-22-2013, 06:17 PM   #4
GAStreamin's Avatar
Moultrie , Georgia
I like this answer!!
Old 05-22-2013, 06:28 PM   #5
W , New England
Thanks but it sounded like I was being a wiseass and I really wasn't. More of a generic (thus unhelpful) answer.
Old 05-22-2013, 06:41 PM   #6
GAStreamin's Avatar
Moultrie , Georgia
It actually funny to me! It is so true. I can worry so much about details and the technical stuff and forget the most important thing, staying cool. Haha!
Old 05-22-2013, 06:49 PM   #7
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
I changed the Attwood heater thermostat in our Bambi to a Dometic digital unit that controls Attwood, the heat strip and the A/C. Now I can control the temperature without getting out of bed no matter what season we are 'streaming....
Bruce
Bruce B is offline   Reply With Quote
Old 05-22-2013, 06:52 PM   #8
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
I think you'll appreciate AC controlled through a thermostat... set it, forget it ... until you want to change the setting.
TB & Greg and Abbey Schnauzer
#3954
Old 05-22-2013, 07:21 PM   #9
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
My answer is: if you're short (like me) you want the thermostat on the wall. If you're tall, anywhere you want it. My world is "different" sometimes!
Kay
Old 05-22-2013, 07:42 PM   #10
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Just be advised that the location of the thermostat will require you to play around until you find a setting that cools/heats to the desired temp. 73 degrees in the bedroom (A/C) allows me to hang meat in the front of my trailer (15,000 BTU unit). The register placement when I have the furnace on also takes some Kentucky windage as the small, round register in the BR doesn't balance with the other registers up front. It's really OK, but you do have to get used to this. AND if you can get used to the heat pump setting on the roof Dometic without your Bose Noise Cancelling Headphones, or your ear protectors -- well, you have some kind of hearing loss!
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 05-22-2013, 07:45 PM   #11
W , New England
Yes, that heat pump is LOUD! If it's cold outside, I think it makes sense to use it during the day while you're out doing other things to take the chill off the AS then switch to the furnace when spending more time inside the AS. But I'm still figuring all this out :-)
Old 05-22-2013, 07:59 PM   #12
GAStreamin's Avatar
Moultrie , Georgia
You are all sharing such interesting things that I didn't know. I didn't know it was so loud!
Old 06-06-2013, 07:27 AM   #13
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
There is another aspect. The thermostat usually has a tighter temp range. Overhead controls sometimes have a +/- of 8-10 degrees, whereas the wall thermostat can be around 3-6 range. What that means is that if you have controls on the ceiling unit, and you think you set it for 70 degrees, it may not come on until it is 75, and may not shut off until 65. That can really impact comfort levels. Many regular units can be controlled by thermostats. Coleman makes a good digital one that incorporates the LP furnace for about $65, but there are also guys that get battery powered ones from Lowes for about $20 and make them work. There are several posts on this at RV Mods, RV Modifications, RV Upgrades, RV Tips, RV eBooks | ModMyRV.com .
robwok is offline   Reply With Quote
Old 06-27-2013, 07:06 PM   #14
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
thanks for the link, cool site
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
