Old 06-14-2015, 06:19 AM   #1
Lotus
2016 27' International
Nebo , North Carolina
AC wiring
Does anyone else have this issue. Lost 12volt power to thermostat control. Moisture got in the pin jack plug that runs to the control. It shorted the connection disrupting power to control hence no air from either unit. The electrical connections are sitting in close proximity to evaporator coils. In hot humid NC now these will sweat and produce moisture that falls down near these connections. All condensation runs out tube to outside normally but this slight amount of sweating does not. Any suggestions how to "waterproof" these. I see this recurring again due to position of this wiring. There is no space available to reposition these to escape the moisture.
JimGaskill is offline   Reply With Quote
Old 06-14-2015, 06:28 AM   #2
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
http://www.amazon.com/Heat-Shrinkabl.../dp/B0042YUAR8
mayco is offline   Reply With Quote
Old 06-14-2015, 07:28 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Use some dielectric silicone.
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-23-2015, 02:04 PM   #4
Lotus
Did both. There is no room to reposition them. Dealer agreed this would be an on going issue let as it was. They perform well now.
Water pump wiring and proper wiring Supertwin1 Water Heaters, Filters & Pumps 8 05-23-2014 07:05 AM
Is House Wiring the same as Automotive Wiring? swebster Mechanics Corner - Engines, Transmission & More... 7 06-15-2004 06:11 AM
TV Antenna wiring??? tenrsingr Audio, Video & TV 6 05-06-2002 02:16 PM
Electric Brake Wiring JW84345 Brakes & Brake Controllers 3 03-26-2002 09:40 PM
Our Airstream trailer wiring FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-15-2002 09:43 PM
