Old 03-03-2016, 08:05 PM   #1
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
AC Upgrade to 15,000BTU
Since I didn't see a forum thread that included the AC unit, I guess it goes here.
I have a 2002 Classic with a very noisy and inefficient 13,500 unit. In very hot environments it barely keeps up. I had NW Airstream in Caldwell, Idaho look into switching me to a new, more efficient 15,000 unit. It will fit. My question is whether the breaker box is sufficient and if there are any stumbling blocks I'm not seeing. Please advise and thanks.
pappy19 is offline   Reply With Quote
Old 03-03-2016, 08:25 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Technically, you will need:
• a new Dometic Penguin II 15K heat pump or cool only upper unit
• probably a new lower interior air distribution box
• a new Dometic drip kit with extra gasket
• a new Dometic Comfort Control Center II thermostat
That's it. Your existing 20 amp breaker is sufficient for the demands of a new 15K unit.
Old 03-04-2016, 09:17 AM   #3
1990 32' Excella
jonesboro , Arkansas
We went to a domestic 15000 and still had cooling prob. On checking we had cool air leaking into the air return. We had 38 to 42 degree air while compress running but cool air caused the thermostat to kick off the compressor. Apparently according to the dometic tech rep i talked to this is a common issue.he suggested what i did.Pulled the interior distribution down put 3\8 in foam strip along all contact edges alum HVAC tape to seal the blower tube cut thin strips of tape and sealed all seams and joints in the air return box.none of this can be seen from the out side except for about a 1\16 in black line around the edge from the foam. I took a razor and cut the excess foam away. All the AC units are designed to fit flat surfaces. Took about 2 hours and worked..
joel is offline   Reply With Quote
Old 03-04-2016, 02:25 PM   #4
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
did you have to lift the unit up or this is under the panel so to speak..
subscribing
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 03-04-2016, 04:15 PM   #5
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
Dometic does not make a 15k Penguin. The next step up is a 'high efficiency'. I have one and the plate on it says 13.5k. I think that the 'high efficiency' is tuned to run 'hotter'. I do not no for sure. If I had to do it all over again I would save the money (about $200) and just buy the 13.5k. The 'high efficiency' draws more amps, has more freon and weighs more. I would bet it is louder.
http://dometic3frontend.qbank.se/epi...031957a824.pdf
FC7039 is offline   Reply With Quote
Old 03-04-2016, 05:52 PM   #6
lewster's Avatar
The 'High Efficiency' unit is commonly known 'in the trade' as a 15K heat pump. It's all semantics really. Dometic saw fit to change the name when they came out with the Penguin II line. The older Penguins had the 15K option labeled as such.
It weighs the same, uses the slightly larger compressor with more refrigerant and the same blower motor, base pan, shroud, air box, t/stat, etc. Noise levels should be identical to the 13.5K units.
Old 03-05-2016, 11:18 AM   #7
pappy19's Avatar
Many, many thanks for the information above. I have forwarded this to my AS dealer Service Manager as an FYI. The new Dometic unit is at the dealership and is to installed next week. Until it really gets warm, it may be difficult to judge the end result. Thanks again and any additional info on this swap will be gratefully accepted.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
Old 03-06-2016, 06:18 AM   #8
carl2591's Avatar
2005 31' Classic
that is interesting.. are the condensor and evap coils any larger as well. Not seeing how a large compressor and a bit more freon can make a 1,500 btu difference. Like you said it might all be on paper.
Carl, Raleigh NC
Old 03-06-2016, 07:18 AM   #9
lewster's Avatar
I've never dissected the units in tandem, so I can't say this as fact, but I would assume that given their stated capacity increase, both a larger compressor and enhanced coil area both should be in play to account for the increase in refrigerant capacity.
Old 03-06-2016, 09:06 AM   #10
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I had a 13.5K Penguin in my 2001 27' Safari. My first trip was in 104 degree weather and we were in the mid 80's in the trailer. In the same campground next to me was my former SOB. It was 30' with a 13.5K Duo Therm. It was 10 degrees cooler inside. That's when I learned that my lesson regarding how well the aluminum conducts heat. Bottom line the dealer and Jackson Center both checked out the air conditioner and pronounced it was working to specs, but was undersized when we experienced high temperatures. I promptly added a street side long awing which helped a lot. When I ordered my Classic, 13.5K was still the standard A/C. I opted for the 15K heat pump model and have never experienced a hot trailer again.
I think most Airstreams 27' or longer should use a 15K unit, and if you travel in hot southern or southwest climes, 2 units should be the standard.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 03-06-2016, 10:18 AM   #11
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Is your new AC going to be installed with the drain cups vs the drain pan?
Kelvin
Old 03-08-2016, 01:52 PM   #12
pappy19's Avatar
The new drain cups as they come in the new AS models.
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
Old 03-09-2016, 03:26 PM   #13
carl2591's Avatar
2005 31' Classic
when you say drain cups is that sorta like on a self defrost refrigerator the water drains into a pan that the fan blows across to evaporate it during cooling operation.
has that proven to be a good system thus far??
Carl, Raleigh NC
Old 03-09-2016, 04:52 PM   #14
lewster's Avatar
Nope!
Dometic's drain cups are placed on the bottom of the base pan, directly below the drain holes which come from the drip tray under the evaporator. The condensate is channeled thru the included hose and connects into the internal drain line that is placed in every Airstream trailer.
This allow for the condensate to be directed to an opening at the terminus of the internal drain hose and allows the water to flow, usually inside a wheel well so it does not drip onto the roof and exterior aluminum.
They work exceptionally well…..WHEN PROPERLY INSTALLED!!!
Axle upgrade markdoane Axles 12 04-14-2004 06:42 PM
Fuel Injection Upgrade? Buck58 General Motorhome Topics 10 11-19-2003 04:47 PM
Amarillo Upgrade Package joshua32064 2003 Safari 5 09-28-2003 08:14 AM
Overdrive (ie; US Gear) VS trans upgrade ... Hayseed Mechanics Corner - Engines, Transmission & More... 24 07-17-2003 08:19 AM
Rear bed frame upgrade ViewRVs Airstream Motorhome Forums 3 05-10-2003 09:53 PM
