Old 05-30-2011, 07:55 AM   #1
Blockstream's Avatar
AC unit won't start
We have a 2006 25ft Safari FB. Our Duo-Therm AC unit stopped working yesterday, however the Comfort Control Thermostat still works. I checked the circuit breaker and fuses and all seems normal. Anything else I should try before I bring it in for servicing?
Blockstream is offline   Reply With Quote
Old 05-30-2011, 08:05 AM   #2
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
More information please. Does the unit blow air at all? Does it blow hot air instead of cold?
My 2006 FB has the 11,000 BTU Duotherm on it and I was able to fix it last month as it was blowing hot air not cold
RichHog is offline   Reply With Quote
Old 05-30-2011, 08:53 AM   #3
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Does the fan work when in fan only mode?
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 05-30-2011, 09:11 AM   #4
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Try a Reset
Sounds like the same thing that happened to me. Try this:
http://www.airforums.com/forums/f427...tml#post421590
Randy
Randy and Pat Godfrey
Region 3 2nd VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 05-30-2011, 09:31 AM   #5
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Welcome to the Forums, Blockstream. We hope you will find what you need - and share with us how your fix progresses.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 05-30-2011, 09:35 AM   #6
AC unit won't start in fan mode either. Thanks for the tips, but I think I'll have to bring it in for servicing. I'll post the results when I have them.
Old 05-30-2011, 12:15 PM   #7
Reganzo's Avatar
2006 34' Classic S/O
Lakewood , New Jersey
I had the same issue, but I found that I had a switch that goes one way for the microwave, and another for the air conditioner. If I forget to turn the switch to air conditioner then nothing happens.
Regards,
Reganzo
Reganzo is offline   Reply With Quote
Old 06-04-2011, 09:00 PM   #8
I brought our Airstream in to be serviced, and it turns out a wire needed to be replaced. Much better than having to replace the entire unit! Thanks to everyone who tried helping us!
Old 06-06-2011, 04:40 AM   #9
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Try turning it on, and you might hear some humming...be sure to have the lower inside cover off...reach up in there and give that squirrel wheel a tug downward towards you...sometimes those wheels have to be oiled.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Adding an AC Unit Alamo Furnaces, Heaters, Fireplaces & Air Conditioning 0 04-10-2011 07:51 PM
A 'streamer has passed: Attention Michigan Unit Minno WBCCI Forum 11 04-05-2011 08:19 AM
Summer AC Unit on 1966 Tradewind- need help please poezlaw Furnaces, Heaters, Fireplaces & Air Conditioning 9 03-22-2011 10:53 PM
NM Unit and 4CU Jemez Mountains Joint Rally LHall WBCCI Rallies & Events 0 01-05-2011 07:27 PM
