Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 06-18-2006, 11:22 PM   #1
Rosie39j
The Silver Biscuit
Profile:  2004 28' International CCD
AC Unit dripping condensate
Anyone know what would be causing my AC unit to drip excessively with condensate?
Rosie39j is offline   Reply With Quote
Old 06-19-2006, 12:21 AM   #2
bhayden
bhayden's Avatar
Profile:  1978 24' Argosy 24
Woodinville , Washington
What's excessive and where? I'm seriously asking. We had the chance to try out our AC this weekend for the first time. Noticed a "big" wet spot under where the kitchen is and thought there must be a leak in the plumbing. Then I saw there was some sealant under the trailer where the puddle originated and after turning off the AC realized that's what was causing the "leak". Car AC can do the same sort of thing.
bhayden is offline   Reply With Quote
Old 06-19-2006, 06:44 AM   #3
ZoomZoom
Profile:  1960 24' Tradewind
Riverside , California
Just like that glass of iced tea that gets all wet on the outside of the glass. Enough relative humidity and the same thing happens to your AC, until the interior humidity is reduced you'll have some condensation on anything cooler than the surronuding air. Try setting your themostat higher initially and stepping it down gradually. Tough to do as good as all that cold air feels.
Zoom
ZoomZoom is offline   Reply With Quote
Old 06-19-2006, 07:44 AM   #4
OpenHigher
OpenHigher's Avatar
Profile:  2006 Safari SE
Los Alamitos , California
Hello Rosie and BHayden:
When we first bought our A/S, 2006 Safari, we had a leak from the A/C after the first heavy rain. The A/C had never even been turned on. Turns out there was a small crack in the condensation pan, which is located in the A/C toward the right front corner (if you were standing in the front of the trailer looking to the rear). Anyway, dealer replaced the pan and the fittings, and now she works fine both when turned on and in rainy weather.
Best, Robert
OpenHigher is offline   Reply With Quote
New Unit Homepage Pahaska Our Community 4 10-07-2002 01:58 PM
Unit Rally jcanavera The Rally Zone 0 08-18-2002 10:15 PM
Armstrong AC unit pics FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 8 08-05-2002 04:26 PM
Removing the Armstrong AC unit FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 11 08-02-2002 12:10 PM
Need info on A/C unit on a 1975 26 ft Argosy ... Hayseed Argosy Motorhomes 0 06-27-2002 09:19 AM
test
