Old 05-25-2014, 01:53 PM   #1
Louisville , Kentucky
Question AC Unit
I installed a new Dometic low profile AC unit last year.The new unit was put to good use this year in Florida and worked well,except my neighbors sail it was to loud.Also my wife complained it was very loud inside the coach and it was.The unit works perfectly,talked with Dometic technical department and they said the high efficiency unit is noisy .Need some expert advise on what to do. Thanks good wrench.
goodwrench is offline   Reply With Quote
Old 05-25-2014, 02:08 PM   #2
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
I too think this unit is loud as I walk a campground and compare. It is advertised as a15K unit but look at the plaque on it and the Dometic documentation it says 13.5K. I suspect they speed up the fans and such and this accounts for the noise. This is my hypothesis.
FC7039 is offline   Reply With Quote
Old 05-25-2014, 03:15 PM   #3
ASTailgate's Avatar
1981 28' Airstream 280
Thanks for posting this as I was thinking about replacing my 15000 btu's with the new low profile dometics.
ASTailgate is online now   Reply With Quote
Old 05-26-2014, 02:05 PM   #4
cdmagda's Avatar
Images: 51
I too replaced mine last year with a Dometic Low Profile 13.500, yes, they are noisy!
cdmagda is offline   Reply With Quote
Old 05-26-2014, 02:40 PM   #5
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
It is what it is.
Ahab is offline   Reply With Quote
Old 05-27-2014, 06:10 AM   #6
Dean E's Avatar
1989 32' Land Yacht
Oakton , Virginia
For the gadget-minded, Radio Shack sells a sound meter that is simple and very easy to use. I have used it at work to identify and replace noisy office equipment and at home to accurately identify exhaust fans.
Sent from my SPH-L720 using Airstream Forums mobile app
Dean E is offline   Reply With Quote
Old 05-27-2014, 01:45 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
All RV rooftop a/c are loud. The low profile, high capacity Dometic is certainly not the most quiet of the bunch.
If it's just compressor and fan noise there's not much of anything that you can do about it, except to be glad that you don't have a heat pump (they're worse).
If there is a rattle then chances are something's loose. I get up on the roof and pull the covers off of mine every 2 years to look for loose items, broken cable ties, blockages, etc.
Old 05-27-2014, 03:08 PM   #8
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Another option that's free or low-cost (depending on the app chosen) is a sound-meter app on a smart phone. This probably has less definitive reading, but with the same phone and app results should be comparable from one reading to the next. I just wouldn't want to take a reading with my Android phone and compare it to a reading made with a precise, calibrated dedicated sound meter.
— David
Old 05-27-2014, 03:42 PM   #9
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Yup, we have one. Yup, they're noisy. Are they the worst on the market? Nope. Not the worst we've ever had, either. We don't use it unless we really need it. And when we need it, I'm grateful for it. I don't think it's noisy on the outside, although I know when it's running and I'm outside.
Kay
Old 06-20-2014, 12:27 PM   #10
ASTailgate's Avatar
Just got my a/c's installed. Quiet and you can feel the air from the rear BR to the drivers seat. Click image for larger version
Name:	ImageUploadedByAirstream Forums1403288858.838253.jpg
Pensacola Unit vs. Big Bend Tallahasse Unit gypsymoth WBCCI Forum 23 04-07-2013 11:19 AM
shopping for a unit to join at unit rallies GoNomad WBCCI Rallies & Events 35 11-30-2006 03:01 PM
Removing the Armstrong AC unit FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 11 08-02-2002 11:10 AM
Need info on A/C unit on a 1975 26 ft Argosy ... Hayseed Argosy Motorhomes 0 06-27-2002 08:19 AM
Washington Unit LKappenman Link Archive 0 05-22-2002 07:38 AM
