Old 07-21-2011, 04:26 PM   #1
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
AC thermostat questions
Can anyone tell me how check my thremostat to see if it's working.I read somewhere about jumping wires but I can't seem to find that thread.
My AC isn't getting cold.
desertair27 is offline   Reply With Quote
Old 07-21-2011, 05:01 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you have a wall mounted thermostat just jump the to wires leading to it.
Highly unlikely it is the thermostat as all that is a simple single pole switch.
You say the AC is not getting cold. First off I am assuming the fan is running. If so and lowering the thermostat or jumping out the thermostat should cause the compressor to come on. If the compressor does not come on after a minute odds are it is bad. If it comes on and the unit is not putting out cold air the unit may have lost its charge or if you are lucky the coils may just be very dirty.
You can clean the coils by dropping the shroud and removing the hold down bolts to get access to the face of the coil. With a spray bottle of Simple Green spray the face of the coils and let it sit for a bit. Now with a spray bottle of water or better yet a weed sprayer with water, more pressure, wash down the coils.
2004 Excursion 4x4
Old 07-21-2011, 05:33 PM   #3
x
XXXX , XXXX
here is a link to a service manual for the Armstrong A/C units. It may not be for your model but most of the information is similar.
http://service.airstream.com/files/l...f18e4e4aa2.pdf
wasagachris is offline   Reply With Quote
Noob with tons of questions! 8string Full-Timing 14 07-20-2011 12:55 AM
[Q] MC16c thermostat stuck flashgrbiv Refrigerators 4 05-21-2011 09:48 AM
Suburban furnace thermostat install? adwriter73 Furnaces, Heaters, Fireplaces & Air Conditioning 6 04-04-2011 02:05 PM
where does the 24 volts come from to thermostat 386kustoms Furnaces, Heaters, Fireplaces & Air Conditioning 20 02-06-2011 05:11 PM
A couple Overlaner questions. DougZ 1972 Overlander 2 01-17-2011 05:04 AM
