Old 09-10-2007, 10:06 PM   #1
Siamese66's Avatar
1976 25' Tradewind
Seattle , Washington
AC shroud side vents...?
Is it prudent to cut side vents in my 76 replacement shroud? It only came with rear vents from Inland. My factory shroud had two on each side. I'd rather not cut. However, is this side venting to keep the Armstrong AC from overheating?
Siamese66 is offline   Reply With Quote
Old 09-11-2007, 04:32 AM   #2
Do not cut the holes.
Mistakes happen.
You have the wrong shroud.
We will contact you this morning to arrange for an exchange.
Sorry.
Old 09-11-2007, 11:02 PM   #3
Siamese66's Avatar
1976 25' Tradewind
Mr Andy, I apologize... I meant about vents for the upper part to the shroud. I actually like it for the fact that there is only one on the bottom left and right side part. I guess I shoulda called and asked? I checked at InlandRV part site. It's the right part #69831. Thank you for the quick response. Sorry for the inconvience.
replacement a/c shroud? roof vents? Dave Cole Furnaces, Heaters, Fireplaces & Air Conditioning 9 12-05-2009 07:00 PM
Side to Side Leveling gorrissen Jacks, Stabilizers, Lifting and Leveling 26 08-02-2009 07:50 PM
Side to side leveling: can I use the stabilizer jacks? iAirstream Jacks, Stabilizers, Lifting and Leveling 4 08-17-2007 07:33 PM
Side-to-Side Flooring Replacement in Classic MH Eddy Repairing/Replacing Floor &/or Frame 12 11-03-2006 01:08 PM
Weight Distribution, side to side JimC Towing, Tow Vehicles & Hitches 8 08-13-2003 03:19 PM
