Old 05-06-2011, 10:28 PM   #1
1972 27' Overlander
Talent , Oregon
AC Shroud
I have a 1972 Overlander, 27 Ft. The AC Shroud needs to be replaced, is this a universal part or do I have to get it from Airstream. I Have looked online and most of them are for Colemans...Thank you for your help
skerby is offline   Reply With Quote
Old 05-06-2011, 11:23 PM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
Well, what kind of AC do you have? Inland RV sells shrouds... you can also consider fabricating your own; some possible construction methods are riveted aluminum or epoxy&fiberglass covered foam/wood.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 05-06-2011, 11:54 PM   #3
The original shroud is available, but made with fiberglass instead of plastic.
Old 05-08-2011, 07:06 AM   #4
blickcd's Avatar
Milford , Ohio
Skerby, I have the shroud for my old Armstrong air conditrioner. It is in fair condition and I'd consider giving it to you so long as you paid the shipping from SW Ohio. Might be too big to send UPS. Send me a PM if you are interested.
Christopher
ID:	129340   Click image for larger version
blickcd is offline   Reply With Quote
Old 05-08-2011, 08:18 AM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Christopher
Before the OP gets too excited, that shroud won't fit the '72 Armstrong. The '72 had two fan motors with their vent holes in the shroud in different locations, instead of a single motor doing double duty.
Old 02-16-2015, 12:05 PM   #6
1972 27' Overlander
Panama City Beach , Florida
What is the supplier source for the fiberglass shroud you reference?
Barry Mabus is offline   Reply With Quote
The Fun Begins wasagachris 1973-1974 Excella 500 684 09-26-2014 07:16 AM
Airstreams and leaks Julie B Leaks - Weatherstrips, Gaskets, Caulks & Sealants 71 07-13-2012 04:38 PM
TR21-12 Shroud supplier avisjean Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-20-2011 08:47 PM
HW Removal - Confused and Distressed... help? robwok Water Heaters, Filters & Pumps 20 03-17-2011 05:41 PM
A/C shroud color... Dwight Furnaces, Heaters, Fireplaces & Air Conditioning 7 03-15-2011 06:52 PM
