Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 04-16-2007, 02:49 PM   #1
1960airstream
Wayward Traveler
Profile:  1993 34' Limited
1960 26' Overlander
1958 22' Caravanner
San Diego , and Quartzsite AZ
AC Replacement Question
Hi folks: I have a 93 34 Limited and the original factory AC died the other week during our recent 100 degree weather here in Western AZ. In prep for my replacement ACs arrival I went ahead and removed the old one which is a Dometic Penguin. After getting the mechanical works off of the roof, I went to remove the plastic bottom pan and found that it was adhered with gobs of waterproof caulking essentially sealing it to the roof. I had to destroy the pan to get it removed and deal with quite a mess to get the surface prepped. My previous experience with AC units was that they were usually installed with a foam gasket.
Does anyone know if this was a typical factory recommended installation method instead of the foam gasket? Is caulking a method I should consider in the reinstallation process?
Thanks for the help......
John Starcher.......Quartzsite AZ
1993 Classic Limited
1960 Overlander
1958 Flying Cloud
1954 Safari
1960airstream is offline   Reply With Quote
Old 04-16-2007, 03:38 PM   #2
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
Drip pans are OEM equipment, and should be replaced if you are installing a new Penguin. This channels the water from the evaporator to a drain tube instead of running down the side of the trailer.
Old 04-16-2007, 03:54 PM   #3
markdoane
Profile:  , Minnesota
Images: 59
It depends on who will be working on it next. If your initials are JC or CW, you let the next guy worry about it.
If it was me, I would use putty around the edges and the foam gasket, modified to clear the water channel.
Non-contributing deadbeat.
Old 04-16-2007, 04:03 PM   #4
myboyburt
NEU 1VP 2008-2009
myboyburt's Avatar
Profile:  1993 25' Excella
1977 Argosy Minuet 6.0 Metre
New Boston , New Hampshire
Images: 12
We just had a new A/C installed on our 93 Excella
The Dealer installed the Penquin A/C along with the Airstream A/C drip pan - part # 961270 (drip pan only) and they used SikaFlex caulk to seal the unit to our rig.
Oh, our old A/C was sealed to the rig with caulking too. Direct from factory.
Michelle & Leon
WBCCI # 7032 Region 1, New England Unit
Looking for a WBCCI Unit filled with fun loving folks to camp and travel with in the New England area? Well, you've just found it:
myboyburt is offline   Reply With Quote
Old 04-16-2007, 04:05 PM   #5
AYRSTRM2
AYRSTRM2's Avatar
Profile:  1966 22' Safari
Armada , Michigan
Carrier AirV ACs don't require ANY caulk or sealer, nor drip pan. You can modify it slightly to run down the drip tube you already have, but the "drip pan" is integrated into the design.
John
Visit my Camping Blog!
AYRSTRM2 is offline   Reply With Quote
Old 04-17-2007, 01:17 PM   #6
1960airstream
Wayward Traveler
1960 26' Overlander
1958 22' Caravanner
Thanks for the info....
Thanks for the responses. I am getting a Carrier 15k Low Profile and will do some more research on integrating the existing drip line into the new AC. Regards....John
John Starcher
Wayward Travels Vintage Services
San Diego, CA
Water heater replacement Craig Water Heaters, Filters & Pumps 35 06-18-2007 07:47 AM
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 09:05 PM
Floor support question jeanarlene Repairing/Replacing Floor &/or Frame 1 10-11-2002 11:26 AM
Door Lock replacement? 3Ms75Argosy Doors & Locks 2 08-16-2002 12:12 AM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 01:08 PM
test
