Old 01-24-2016, 04:32 AM   #1
terrencecolp's Avatar
1976 25' Tradewind
Tulsa , Oklahoma
ac repair
Is a 76 Armstrong with a bad compressor worth repairing? I will buy a new one if not, but I hear horror stories about cutting and bracing and handling and condensation drip so I don't know which way is easier.
terrencecolp is offline   Reply With Quote
Old 01-24-2016, 08:14 AM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I love my old Armstrong, it is still running entering its 43rd year, and I have worked it HARD over the past few years.
I am one who says to try and fix it, but whatever you do please don't throw it away!
Replacing a compressor isn't a big deal, but finding someone to do it might be.
Are you sure it is the compressor and not a bad relay or capacitors?
Brevi tempore!
Old 01-25-2016, 05:25 AM   #3
1976 25' Tradewind
Tulsa , Oklahoma
I'm pretty sure it's the compressor. It only cools about half what it used to before blowing a fan capacitor and running without a fan for ten minutes. A friend of mine works in HVAC and thinks he can work on it. If the Armstrong is worth fixing I would rather go that way.
Old 01-25-2016, 07:28 AM   #4
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Yea, it sounds like it. There are lots of threads on here about fixing these units, this one is an example, although when I fix mine I wont go to the trouble of making it a heat pump..
http://www.airforums.com/forums/f427...dor-76432.html
Brevi tempore!
Old 01-25-2016, 08:07 AM   #5
Mission , Texas
If it is cooling at all the compressor is likely not the problem. The freon charge and oil are more likely.
nrgtrakr is offline   Reply With Quote
Old 01-25-2016, 09:40 AM   #6
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Imho, taken the events presented in mind, the compressor over pressured and/or overheated while running without the fan. Likely it still pumps, but not efficient enough to properly cool.
Sometimes the pump units fail or partially fail while the motor side can still work.
Brevi tempore!
Old 01-27-2016, 05:32 AM   #7
1976 25' Tradewind
Tulsa , Oklahoma
J.MORGAN, That was my thinking, but I will make a thorough inspection to see if I can spot a leak. I know if it needs charging I'll have to have a valve installed. Whatever is wrong, I believe the unit is worth at least trying to fix. I know when it was properly working it sure cooled my trailer well, even in an Oklahoma summer in full sun.
Dash Repair Questions JW84345 Airstream Motorhome Forums 15 07-15-2012 08:59 PM
Plastic bathroom components crack repair with 3M 4240 semi-rigid plastic repair kit Top Upholstery, Blinds, Walls & Interior Finishes 1 05-09-2011 07:11 PM
1961 Dometic Refrigerator - Best Repair Shop? Andy R Refrigerators 18 03-21-2011 08:07 PM
shop repair of 1970s rear frame separation (non elephant ears repair) RV shop review simonhanbury Repairing/Replacing Floor &/or Frame 49 06-24-2008 09:16 AM
My repair day 3/9/02 ViewRVs Airstream Motorhome Forums 8 03-10-2002 04:29 PM
