Old 06-01-2004, 01:01 PM   #1
tinman7's Avatar
1976 27' Overlander
St James City , Florida
Images: 13
Ac Relay ?
Wondering if anyone knows where I could get a start relay for my 76 overlander armstrong ac? Went looking local but no luck.I replaced the start capactior and it didn't start so I jumped the realy and the compressor started and got cold. I dont know if I could just by pass this or what...any thoughts? Frank
tinman7 is offline   Reply With Quote
Old 06-01-2004, 01:26 PM   #2
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Most likely, the breaker will trip if you wire straight through.
Capacitor is intended to store voltage and release as a burst to overcome the slow start and subsequently trip your overload protection.
Smily
smily is offline   Reply With Quote
Old 06-01-2004, 01:46 PM   #3
tinman7's Avatar
1976 27' Overlander
Images: 13
relay
Thanks Ken, I don't think I explained it well enough. The capacitor is fine its the relay thats shot.I guess its like a switch to energize the ac and not the heat strip and then when the t-sat ask for heat it will switch to that or off?
I dont need the heat so maybe there is a different switch that I could use.
Frank
Old 06-01-2004, 06:05 PM   #4
jaco's Avatar
Heat strip ???
I did not know the Armstrongs had such a thing.
Please tell me more.
jaco
jaco is offline   Reply With Quote
Old 06-01-2004, 08:31 PM   #5
tinman7's Avatar
1976 27' Overlander
Images: 13
I guess you could call it heating element.It dosen't do much but it will take the chill out of place.It works from the same armstrong t-stat thats all I know...
Frank
Old 06-02-2004, 06:45 AM   #6
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
If you are looking at what I think you are, a better name might be "A/C main relay". Most thermostats work off of 24 vac supplied by a small transformer located somewhere on the A/C unit (Davidz71 knows where it is). When the thermostat signals 'cooling', 24 vac is sent to the main relay, whose contacts close, and supply 120 vac to the compressor.
Any store that sells HVAC and/or appliance parts should have a replacement relay, although it might not be physically the same size. Make note of how much room you have to play with, and take the old relay with you. The relay contacts will be rated in either amps@120 VAC, or horsepower. If you're lucky, the rating is stamped on the relay. If you're not, get a relay rated at at least 15 amps @ 120vac or 2-1/2 hp.
But then again, you might be looking at something else altogether
Tom
Old 06-08-2004, 06:35 PM   #7
Tinman7
We have the start relays for the Armstrong AC's.
Old 06-08-2004, 06:50 PM   #8
tinman7's Avatar
1976 27' Overlander
Images: 13
Andy,Thanks for the reply.I picked up a single pole 30 amp relay at a local electric store,they were not sure if it would it would work.I put it in and the unit kicked in and seamed to work fine. I hope this part is ok and not cause harm. What do you think?
Frank
3rd battery for less than 10 bucks john hd Batteries, Univolts, Converters & Inverters 18 09-17-2007 07:34 PM
Suburban furnace.. need relay.. Happycampers Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-10-2004 02:35 PM
Astrodokk on the road-tail lights out PeterH-Airstreamer Airstream Motorhome Forums 10 12-02-2003 07:35 AM
Bumper Halogen Lights - '88 Classic 345 MH jslee77 General Motorhome Topics 2 11-24-2003 11:23 AM
Suburban tow package wiring question uwe On The Road... 9 08-29-2003 02:08 PM
