Old 07-01-2011, 10:14 PM   #1
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
AC Question-
Just wondering if my 2002 Classic AC will run on a 110 plug-in. If that's the only thing I run, will it work? What, if anything else, will also run with 110, and what happens on over-load. Does it blow the breaker in the AS or at the house it is plugged into? Thanks-
Pap
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 07-01-2011, 10:34 PM   #2
1985 31' Excella
Fresno , Texas
First thing all of the trailer is 110v. If you have a 12,000 BTU and no extra extension cords it will probably run but its is not recommended. If you have a 15,000 BTU I doubt it will run. I am assuming you are talking about using a adapter and plugging into a 20 amp plug.
If it starts slow turn it off.
Wsmith is offline   Reply With Quote
Old 07-01-2011, 11:46 PM   #3
1972 25' Tradewind
Madison , Wisconsin
Some air conditioners will run on 15 and 20 am circuits, I have one rated at 12650 btu and it will run fine on a 20 amp. According to the specs it should also run on a 15, but it was getting up there where the starting amps could be iffy. Check your manual or the AC literature, there should be a table that shows the power requirements for starting and for running.
Anything approaching 1500 will need a 30 amp. A 13500 with a hard start capacitor should be able to go on a 20, but check the specs to be certain. Most 13500 should be on a 30 amp circuit.
You could also have an electrician put in a 30 amp service plug and just use an RV converter plug. It is not a difficult task for them and they can put in a weather resistant lock box for the 30 amp service.
Smokin Camel is offline   Reply With Quote
Old 07-02-2011, 07:15 AM   #4
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
The biggest thing is to have a heavy gauge extension cord, and keep it as short as possible. The AC runs on a 20-amp beaker in the trailer. 20 amps are 20 amps, so long as you manage the loss in the cord it will work fine.
Electricity is like water, the longer the pipe the more pressure and flow loss. So one uses a larger pipe for long runs.
A 10-gauge cord up to 50 feet should run it fine. Minimize the load on the receptacle you plug into to make sure you are getting the full current.
To run mine, I replaced the 15 amp standard household female plug with a 30 amp RV plug so I could plug the trailer umbilical into it without an adapter. It stopped tripping breakers and measures 120 volts in the trailer, even when starting.
Regards,
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 07-02-2011, 09:07 AM   #5
Goal15's Avatar
Dallas , Texas
We can run our 11k Penguin at the house with adapter and two rv power cords with no problem whatsoever. Longest we have run it is about 8 hours during the sunny day and it has been okay
Goal15 is offline   Reply With Quote
Old 07-02-2011, 02:58 PM   #6
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I tried running ours on a 20a circuit. It seemed ok and ran for awhile but after some time ( I wan't checking ) it popped off. It was the circuit breaker in the garage that popped and not any in the trailer. So I guess mine needs the 30a to run. I have a generator to try but I have to see if it has a 30a plug to be sure.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Steel / Aluminum wheel question polarlyse Wheels, Hubs & Bearings 12 05-29-2011 07:49 PM
1980 Caravelle axle question Seymour Axles 5 05-14-2011 08:28 PM
A question on selling awnings Airy Awnings 21 04-24-2011 10:37 AM
EVAP Canister? question 8rmesse Classic Motorhomes 23 04-24-2011 06:41 AM
Blasphemous question woytovich General Repair Forum 15 04-09-2011 08:36 AM
