Old 04-10-2011, 06:49 AM   #1
vintage travelers
scorpiontimo's Avatar
1972 31' Sovereign
Johnson City , on the road
Images: 20
Ac question
Can anyone tell me if you can upgrade an ac thermostat I have an older unit 71 trailer with 71 ac unit I want to change the old controller thermostat to a newer one that adjusts by temp not high and low on and off like I got now. has anyone done this ?
scorpiontimo is offline   Reply With Quote
Old 04-12-2011, 05:09 AM   #2
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Ac upgrade
I would also like to replace the control knobs on the AC unit with a wall mounted thermostat so it could be set at a desired temperature. The unit is a late model Coleman. A heating/Air tech said I needed a relay kit of some kind. I have seen it done but don't know how it was done. Any thoughts? Thanks
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 04-12-2011, 05:39 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I've used a digital household thermostat for our old A/C. Just disconnect the old one, connect the new one, and put a battery in it. You will need to decide whether you want the blower fan to be high or low when you hook it up. You'll only have one fan speed. I chose "low" when I hooked ours up.
Old 04-12-2011, 06:11 AM   #4
vintage travelers
1972 31' Sovereign
Images: 20
Thanks just what i wanted to hear will try one today safe travels Patrick
EVAP Canister? question 8rmesse Classic Motorhomes 23 04-24-2011 06:41 AM
Blasphemous question woytovich General Repair Forum 15 04-09-2011 08:36 AM
Es-capin' the cold and a Question Snedwid On The Road... 8 03-12-2011 10:37 AM
Polishing Question NicheVintage Cleaning, Stripping & Polishing 48 02-08-2011 12:04 PM
Trailering Question Cracker Jacks, Stabilizers, Lifting and Leveling 14 01-02-2011 02:55 PM
