Old 04-14-2009, 10:11 AM   #1
tdoescher's Avatar
1969 31' Sovereign
Madison , Wisconsin
AC Question
I have a Coleman Mach 3 on top of my newly purchased 69 Sovereign. I believe it was installed back in 84. When I turn it on it runs but I feel no blowing. Is there an easy fix or repair or would it be recommended I purchase a new unit? What,s the overall experience you guys have had a A/C not working?
tdoescher is offline   Reply With Quote
Old 04-14-2009, 10:27 AM   #2
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Remove the cover in side and check your blower. I had the screw holding the blower to the motor shaft loosen on my old AC and it was just spinning on the shaft. Just a thought.
Don
adonh is offline   Reply With Quote
Old 04-14-2009, 10:31 AM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I have replace the blower motor a couple of times in the Coleman on my Trade Wind. Not difficult, and it still works. You could check and see if your motor has a places to oil it and try that.
Vaughan
Old 04-14-2009, 10:45 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
If the trailer sat for a time the blower shaft may be stuck. Not sure you can get to it from inside but take a look. If you can try and spin the blower. If it spins freely the motor may be shot or just not getting power. To check power you will have to get to the motor wiring and test for voltage while the AC is on. Keep in mind that is a multi speed motor so there will be at least 4 wires going to it.
2004 Excursion 4x4
HowieE is online now   Reply With Quote
