Old 09-24-2003, 11:23 AM   #1
1990 32' Excella
jonesboro , Arkansas
AC problems
Coleman 6759 mach 3 with heat. Heat only works with switch turned to low or high cool and then turning the t-stat to warm.
The element will not come on in the appropriate low heat setting. this unt is original to the trailor and otherwise works great.
ANY IDEAS Thanks
joel is offline   Reply With Quote
Old 11-10-2003, 06:45 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Sounds like the PC board that controls the climate control is messed up, they seem to be famous (or infamous) for that. Maybe Andy from Inland RV could tell you how to check it, if you asked him real nice...
Old 11-11-2003, 09:14 AM   #3
Joel.
Several things to check.
Bad selector switch.
Relay terminals stuck.
Crimped wires shorting together.
Something shorting terminals on the selector switch.
Easy fix?? Disconnect the heating element.
No heat, but fixes the problem.
AC Gasket replacement Sneakinup Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-30-2003 09:07 AM
ac problems wb13798 Furnaces, Heaters, Fireplaces & Air Conditioning 5 09-18-2003 06:53 PM
Fridge doesn't work on ac jwaldin Refrigerators 5 04-10-2003 10:38 AM
Coleman AC Heater Element Pick Furnaces, Heaters, Fireplaces & Air Conditioning 4 12-02-2002 02:04 PM
Yukon AC cuts out towing.... dscluchfc On The Road... 10 07-27-2002 11:01 AM
