Old 09-15-2003, 07:46 PM   #1
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
ac problems
this past weekend wasnt without a few problems . my front ac is on the blink. when i turn it on i hear the compressor come on but the fan doesnt. we ran overhead air for 5 hours on the gene while traveling and when we set up the ac was turned off before shutting the genset of .
after we got all connected up ac wouldnt come on . any thoughts as to what is on the lamb . thnx
al
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
Old 09-15-2003, 08:16 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I had the same thing happen once. I snapped off and on all of the breakers and everything worked again. Don't know why, and it has not happened since.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 09-18-2003, 12:27 PM   #3
wb13798's Avatar
2004 28' Classic
well it pays to do service on your equipment. have been in the process of replacing the ac with a power efficient unit but no drip pan. this fix for my problem is the blower motor has oil tubes on the front of the motor and the rear. a few drops of oil and the motor will run .
the blower motor in the bath stopped running gave it a shot of oil and now is running again. just remove the two screws on the pie pan and pull the squarrel cage off and oil on top at the bearing. lol
al
AL
allison 6 speed
Old 09-18-2003, 05:40 PM   #4
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Your AC has a compressor start capactor and a fan start capactor they are known to fail. Compressor comes on then shuts down as the outside cooling fan failed to start.
This happened to me camping and since I could get at the fan with out taking the unit apart or the shroud off I waited a few minutes had the wife turn the AC back on. I gave the blade a gentle push and it worked the rest of the weekend.
In most cases both capactors are in the same housing so you replace both capactors.
Garry
Old 09-18-2003, 06:43 PM   #5
wb13798's Avatar
2004 28' Classic
garry
the problem was the blower motor was gummed up . after a bit of oil it works just fine. if that didnt work i was going to do the motor start caps. in most cases that would be a good place to start. lol
al
AL
allison 6 speed
Old 09-18-2003, 06:53 PM   #6
wb13798's Avatar
2004 28' Classic
probably should start a new thread but what to heck.
i called coleman today and talked about units that would fit my drip pan . it appears i might be able to get the two ac i want to work in my pans after all.
i want to replace the two i have with the 13500 power saver units as they only need 10 amps to run . would save my genset and i could run both off my 30 amp service.
i pased the model no to a friend who has i think two units and we will see if they match up.
will have to get a new celing unit to make it work cant use the old ones. like some one posted where did the yellow go. one of my celing unit shroud is a bright yellow.
alan
i will post the results. but if you dont have the coleman pans you out of luck they are nla. lol
al
AL
allison 6 speed
AC Gasket replacement Sneakinup Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-30-2003 09:07 AM
AC problems joel Furnaces, Heaters, Fireplaces & Air Conditioning 2 11-11-2003 09:14 AM
Fridge doesn't work on ac jwaldin Refrigerators 5 04-10-2003 10:38 AM
Coleman AC Heater Element Pick Furnaces, Heaters, Fireplaces & Air Conditioning 4 12-02-2002 02:04 PM
Yukon AC cuts out towing.... dscluchfc On The Road... 10 07-27-2002 11:01 AM
