Old 01-10-2006, 07:41 PM   #1
PhiDor's Avatar
2007 34' Classic S/O
The Villages , Florida
Question AC Problems
I have a 94 Excella with a Duotherm Penguin AC. I took the inside cover off to clean it and noticed some black stuff on the inside that looks and feels like soot. The insulation or padding in the center is covered with it and so are the vents at each end. Traces of it all over the inside of the air box. As I looked further, I noticed that the squirrel cage fan is covered with this stuff also. I have to do more investigating.
Now the real questions are:
Did something burn or melt in there to cause this?
Is the black mess all over the ozite fabric caused by this soot and not by mold as I once thought? I just bought this trailer in October and am refurbishing it.
Anyone have any thoughts on this matter?
PhiDor is offline   Reply With Quote
Old 01-10-2006, 07:46 PM   #2
2003 25' Safari
Eden Prairie , Minnesota
Were the former owners smokers? Is there a burnt smell? Please post some photos of what you are finding.
Dan
dmac is offline   Reply With Quote
Old 01-10-2006, 08:12 PM   #3
PhiDor's Avatar
Quick reply
Don't know about the smoking. But we're talking soot like in a chimney. Not just some yellowing from cigarettes. And I'll load some pics as soon as I figure out how to do it.
Old 01-10-2006, 08:15 PM   #4
1972 29' Ambassador
1968 22' Safari
Tyler , Texas
I have had a black mold or mildew form on a window AC unit that looked like soot but was actually a coating of microscopic spores.
26.982 amu is offline   Reply With Quote
Old 01-10-2006, 08:27 PM   #5
PhiDor's Avatar
That's athought. It could be mold. I'm not cleaning this cover until I find out what it is.
I posted some pics, but I can't find them I saw them and then they were gone.
Old 01-11-2006, 07:10 AM   #6
dtbw's Avatar
1999 34' Limited
2002 19' Bambi
Allen , Texas
Another possibility
I have this in more than a few A/Ss that we have had in for service. What typically causes this is a combination of the particles normally found in the air that deposit due to being combined with aerosols from cooking and bathing as the air passes thru the AC unit. Your situation might involve mold, but is more likely just typical airborne dust and dirt that have accumulated. Even though you might not think about such being black, we all tend to forget that cars and trucks emit tons of particles that are in fact soot but just too small for us to notice. Concentrate those over a period of time and bingo, you have a black layer. The only way to know for sure if mold is involved is to have the stuff tested. There are test kits available in home improvement stores, but their validity is always questionable due to variables in how the sample is collected, etc. Only a professional mold remediation firm can give you a rock solid answer.
David Tidmore
GM Roger Williams Airstream
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
Past President Heart of Texas Camping Unit
WBCCI # 7548
dtbw is offline   Reply With Quote
Old 01-11-2006, 07:43 PM   #7
PhiDor's Avatar
Thanks David, for your reply. I am questioning the mold thing because it is almost impossible toremove this stuff. I think it is "oily" and doesn't respond to most cleaners. Bleach doesn't touch this stuff. I'll have to try something that works on petroleum based products next.
Old 01-11-2006, 08:11 PM   #8
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Seal Deterioration?
While 12 years is a little early, black particles may well be dried bits from failing gasket seal between A/C and roof of trailer... They are black foam, and (depending on climate..) eventually dry out and crumble, resulting in black particles flying around and... (sigh..) water leaks! You could test by trying to reach up and poke the gasket from inside, or from outside below A/C, but another method is to aim hose stream of water from all sides at base of A/C, and seeing if water comes down into trailer.. If so, you have a bingo, and part costs less than $20, and shop labor to unbolt A/C, lift and replace gasket is ~ $200. You could do it yourself with a helper, as most RV places sell the gasket, as about a 1" thick sqaure of black foam, 14" by 14"...
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
rear air suspensiom problems wb13798 Airstream Motorhome Forums 19 03-03-2003 07:12 AM
Black water problems Rob Waste Systems, Tanks & Totes 3 08-31-2002 07:34 PM
Auto Battery problems.... kzener40 Airstream Motorhome Forums 10 08-05-2002 06:37 PM
Fridge Cooling Problems 68International Refrigerators 6 07-10-2002 03:53 PM
Speedometer Problems ViewRVs Mechanics Corner - Engines, Transmission & More... 1 05-13-2002 08:00 PM
