Old 05-08-2006, 02:57 PM   #1
blickcd's Avatar
Milford , Ohio
AC power indicator light won't work.
I have a 1979 International 31' center bath, and the AC Power (shore power indicator) light does not work. This light is an LED at the left end of the battery and tank level monitor panel, which is located over the stove.
Having done some research, I know that the original Univolt battery charger (long gone) when plugged in would ground a gray wire and activate that LED. This gray wire is located in the 12 volt fuse panel below the front window, first fuse holder on the left.
In theory, connecting a jumper wire between this gray wire in the panel and the bare copper chassis ground wire for the battery charger will turn on the AC Power indicator. Supposedly others have done this and installed a 120 volt relay to switch on the light when shore power is plugged in and I would like to do the same, however I can not get that indicator to light up.
Here is what I have checked so far: The gray wire between the fuse panel and monitor panel has continuity. There is continuity between the chassis ground wire and random spots on the trailer frame, as well as the negative buss in the fuse panel. No burned out electrical components have been found on the monitor panel circuit board, including the LED I am trying to activate. Note that I have only checked the circuit board at the left end to roughly where the circuit for the battery meter appears to begin.
I know I am being obsessive with this, but I would like to get that light to come on as originally intended. Any suggestions are welcome.
blickcd is offline   Reply With Quote
Old 05-08-2006, 03:00 PM   #2
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Did they have LEDs in 1979?
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 05-08-2006, 03:09 PM   #3
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
b
Uh, yeah. I had one of those unexplicable LED digitial watches in second grade in 1975. Here's the Wikipedia entry on LEDs.
John
Visit my Camping Blog!
AYRSTRM2 is offline   Reply With Quote
Old 05-08-2006, 03:15 PM   #4
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
This was being discussed in the thread I started on Univolt Wiring Replacement, specifically this post, which just refers you to another thread and post, but you'll get there eventually.
John
Old 05-09-2006, 06:39 AM   #5
blickcd's Avatar
Milford , Ohio
In short it looks like there is no easy way to make that light work again.
I've read most of the messages in those links as part of my earlier research. It looks like early 70's models used an incandescent bulb which could be activated by grounding the grey wire. However, the late 70's models with LEDs are more complicated. I did notice power coming in to that light from two sides when checking with a meter, and a pair of diodes evidently keeps it all under control.
The only way I see to make it work again would be to somehow build a portion of the old Univolt circuitry from scratch and connect that to the grey wire. If anyone can provide a schematic that would be great, otherwise I will give up on this for a year or so.
Christopher
Old 05-09-2006, 08:11 AM   #6
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
I use a meter which I peurchased at Camping World. The light did not tell me when power was not adequate, the meter does. All you need to do is plug it in.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 05-09-2006, 10:47 PM   #7
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Just go buy one of those circuit receptacle testers which lights up with 2 yellow lights on the righthand side if the circuit is alive and correct. Plug it into a receptacle easily visible and when shore power is on, so is the circuit tester. It is a cheap and easy way of taking care of the problem.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 05-09-2006, 11:19 PM   #8
azflycaster's Avatar
1975 25' Tradewind
Dewey , Arizona
Images: 62
The PO left both for me....
BTW, this is what good power should look like.
Richard
Old 05-13-2006, 09:57 PM   #9
davidz71's Avatar
1986 25' Sovereign
azflycaster,
That is the exact duplicate of what I have. All my kids are in for Mother's Day and one was to sleep in the trailer last night. I noticed when straightening things out for him to sleep in the back bed that the 110 v. power was at the top of the green and at the edge of the red (128 volts). I do have a Hughes Autoformer but I have never seen it this high.
Craig
AIR #0078
3.73 rear end
Old 05-14-2006, 08:32 AM   #10
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Is it a LED or a Neon bulb ? Is it flat topped ? Mine is Neon and they tend to just fail. If you do a little research you can come up with the circuit as it is very common on boats also. I built a panel years ago and found the circuit on the internet somewhere.
Of course I normally know when shore power is on, the blinking microwave gives it away.
Good Luck Jim
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
"Power On" indicator davidz71 Electrical - Systems, Generators, Batteries & Solar 23 09-15-2005 10:52 AM
marker lights dont work wb13798 Mechanics Corner - Engines, Transmission & More... 6 11-09-2002 12:40 PM
towing and the Banks Power Pack kooblekidz Airstream Motorhome Forums 11 10-31-2002 01:09 AM
Electric meter dienst1 Airstream Motorhome Forums 4 10-20-2002 10:17 PM
New power Convertor HOT! silverbullet Electrical - Systems, Generators, Batteries & Solar 4 09-24-2002 11:01 AM
