Old 02-28-2015, 11:00 AM   #1
1993 30' Excella
Kaplan , Louisiana
Wink AC Operating Question
A friend of mine has a 1997 Limited 34' trailer and is having problems with the cooling and heating system not working properly. He has changed the thermostat, but when you put in the cooling mode, the heat strip comes on and the furnace motor starts and the compressor is also running. What could the problem be. Is it with the thermostat or is with the mother board on the A/C?
jmland is offline   Reply With Quote
Old 02-28-2015, 11:03 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
If you put the subject in the header it might get more responses.
MICHAEL
Old 02-28-2015, 11:08 AM   #3
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Based on what you are saying I would guess it would be thermostat related since the furnace and air conditioner are (at least on mine) independent of each other. The only commonality is the single thermostat control. Other thought assuming the replacement thermostat was the correct one, is that there may be an issue where some wiring in the thermostat area is either touching another or when the wiring to the new thermostat was made, a wire was placed on the wrong terminal connection.
Would anyone know if on this vintage trailer whether the thermostat wires go back to the A/C unit and then travel to the furnace?
Jack
Jack Canavera
STL Mo.
AIR #56
Old 02-28-2015, 11:10 AM   #4
jcanavera's Avatar
Fenton , Missouri
Images: 143
I just fixed it.
Jack
Jack Canavera
STL Mo.
AIR #56
anyone: 10-ply "E" 7-15 Del-Net tire??? jmeredith Tires 13 07-09-2009 06:31 PM
NCC for '88 Excella (Net carring capacity) muthes 1987 - 1989 Excella 3 05-29-2004 03:41 PM
Airstreams & the net... aviontt Our Community 1 12-03-2003 04:31 PM
http://www.wbccimn.net jcooper Link Archive 0 04-06-2002 12:56 PM
