Old 07-12-2009, 10:44 AM   #1
1992 35' Airstream 350
central tx , Texas
AC one or the other????????
Hi, i'm Lefounta: I am new to this site and real new to airstreams, this past February.
I have a 1992 350LE motorcoach. I am still working the bugs out of the "everything on it works great" motorhome.
When plugged into 120 v 30amp shoreline only one AC will work at a time. It has two airconditioners, front and rear. A switch of the common light witch variety in a cabinet above the sink toggles between front and rear ACs. When the generator is in operation, boths ACs will try o come on, if one is not carefull to have one switched off, and bog down and kill the generator.
My question then is: Isn't it suposed to be the other way around, that both ACs would run with the shorline plugged in and one or the other with the genset running?
lefounta is offline   Reply With Quote
Old 07-12-2009, 10:56 AM   #2
They way the AC's are working, is correct.
2 AC's cannot properly run on a 30 amp circuit, not even if just the Univolt is running.
The second AC, will run fine, if you crank up the generator.
That's how Airstream designed it to work.
Old 07-12-2009, 11:29 AM   #3
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
I would think with 2 ACs you would have a 50 amp. service,each ac is pulling close to 20 amps at start up. Dave
easyride is offline   Reply With Quote
Old 07-12-2009, 11:30 AM   #4
crestonrv's Avatar
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
crossville , Tennessee
how many watts is gen set? only 1 a/c on 30 amp shore unless energy managment system is installed on unit. ems will monitor amp draw of loads and stall 2nd compressor untill 1rst is running. also will shed non essential loads to stay within capacity.
if you have 5000 watt or larger gen set it would normally be wired so that primary circuit (30 amp) feeds coach main. secondary corcuit would go to aux a/c only.
crestonrv is offline   Reply With Quote
Old 07-12-2009, 11:46 AM   #5
central tx , Texas
It is definately 30amp. The genset is an Onan 6500
Old 07-12-2009, 12:09 PM   #6
crestonrv's Avatar
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
put switch 2 front a/c then both will run on gen still only 1 on shore.
Old 07-12-2009, 12:12 PM   #7
crestonrv's Avatar
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
if you have switch in front a/c possition and still can't run both a/cs on the gen then you have a problem with either the gen or 1 of the a/cs as 6500 watt onan should handilly run both.
