Old 07-07-2006, 10:52 AM   #1
acrane's Avatar
1980 31' Excella II
Stonewall , Mississippi
AC Not cooling
AC not cooling enough or I am too hot! Seriousy, how do you tell if AC is cooling properly or need freon or needs to be replaced?
I like my trailer Cool!
Also, found ac drain hose ran small metal pipe up it (all the way to the top of the trailer) did not appear to be stopped up, but still getting leaking down side of trailer. Any suggestions?
Alice Crane
acrane is offline   Reply With Quote
Old 07-09-2006, 12:43 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Hi Alice,
The proper differential for a roof mounted RV air conditioner is 18-22 degrees between the intake air temp and the cooled exhaust temp. You might get a couple of thermometers with one at the intake vent and the other where the cool air exits the A/C.
If it does not fall into the 18-22 degree range, you might have dirty or clogged condenser/evaporator coils or clogges intake filters. If your unit has leaked some of the R-22 refrigerant, there is no way provided by the manufacturer to replace it.
If that IS the situation, the entire unit is generally replaced unless you have an Armstrong unit, which has process valves for refrigerant evacuation and replacement. Newer units do not. Most RV repair shops however are not licensed (EPA class I or Universal license required) or equipped to do this type of work. You will need a domestic A/C tech for that.
refrig cooling problem frydmans 1969 - 1973 Safari 12 08-25-2002 06:19 PM
Electric Cooling Fan Settings rdm Mechanics Corner - Engines, Transmission & More... 1 07-12-2002 06:29 AM
Fridge Cooling Problems 68International Refrigerators 6 07-10-2002 03:53 PM
Poor cooling on AC, good on gas Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-13-2002 10:46 PM
Auto trans temps chart FrankR Mechanics Corner - Engines, Transmission & More... 9 05-05-2002 08:42 AM
