Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 10-16-2007, 01:36 PM   #1
plossl
plossl's Avatar
Profile:  1974 25' Tradewind
Greenwood , South Carolina
AC mounted in pickup bed?
Anyone tried it? Why wouldn't it be a less expensive, quieter alternative to the roof mount? I can get a great, very quiet room AC for about 400 dollars. And sitting in the pickup bed it wouldn't vibrate the AS or keep us awake. Would it be that hard to run a duct back to the AS after I've parked? I think I'd cut a duct in the front wall and blow it in low with roof vents to let out the hot. Any thoughts?
plossl is offline   Reply With Quote
Old 10-16-2007, 01:49 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
You need to run 2 ducts, one for cold air, one for return air. Even the most powerful A/C that runs on 120V won't have enough cooling capacity to continually cool down hot outside air. It helps to have a recirculating system, with only a small amount of fresh air added.
Otherwise, it should work just fine, if you keep the ducts short enough, and insulated well.
Why not mount on a cart, like a generator, so you can move it close to the trailer when you need it?
Good Luck with your project. Sounds doable to me, although unconventional. I am sure it is going to have many advantages, solong tha tyou don't mind the extra setup time, and storing it etc.
Uwe
Old 10-16-2007, 02:00 PM   #3
plossl
plossl's Avatar
I like the cart idea, but then I have to move the AC in and out of the truck. I can make it more secure if I lock it into the bed somehow. A return duct is necessary-you're right. I'll have to think about where to run it from.
Old 10-16-2007, 02:07 PM   #4
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
You could go with a spilt system - inside blower unit and outside condenser that could have quick connect fittings. Just remove the outside unit for transport and leave the inside unit mounted all the time. Just the cooling gasses move from inside to outside. Cost would be high but home units are available.
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 10-16-2007, 02:09 PM   #5
plossl
plossl's Avatar
Kind of like central air conditioning . . . good idea!
Old 10-16-2007, 03:01 PM   #6
clancy_boy
clancy_boy's Avatar
1966 17' Caravel
Kiln , Mississippi
Images: 8
Look at these:
ductless mini split air conditioner system mini split air conditioning ac unit -
Michael and Tina BZ
1966 17' CARAVEL
WBCCI 30962
Old 10-16-2007, 03:52 PM   #7
Minnie's Mate
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
Profile:  2006 30' Safari
Fayetteville , Georgia
Last spring I attended a forum rally and a Spartan Manor was there that had a computer room A/C condensing unit mounted to the tongue just behind the LP gas tanks. The cooling coil was located in one of the closets (would probably fit under the gaucho) and the duct work was run through the other closets and under the tub to provide central A/C in both bedrooms, bathroom, kitchen and salon. Very ingenious system. You might try something like that. The owner post on this forum. I'll be with the same rally group in two weeks. If he is there I'll try to get photos and info. Did a super job in upper 80's weather. Sure it would do a great job in most summer temps, too.
Family of Disney Fanatics
WBCCI# 4821
Old 10-16-2007, 05:26 PM   #8
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Once you get the rest of it figured out - seems as though you could route the cold air into the heater duct system for distribution in the trailer.
Dave
Fyrzowt is offline   Reply With Quote
Old 10-16-2007, 09:18 PM   #9
plossl
plossl's Avatar
There must be a way; the question is between a split system (which must be connected under pressure) and a window mount unit that would sit in the pickup bed and be connected with ducting. I'm leaning toward the window mount unit due to simplicity, but I'm thinking I will have to oversize it a bit to compensate for loss.
Honda EU2000s mounted on Bambi grizzy Generators & Solar Power 61 05-30-2008 01:07 PM
Permanent Mounted Generator In 22 CCD MrAgent007 Generators & Solar Power 14 08-02-2007 08:01 PM
Wall Mounted Fan Help rek Roof Vents, Skylights & Fans 2 05-04-2007 01:57 PM
wall mounted tv Sherm Nelson Audio, Video & TV 5 06-22-2006 10:53 AM
GPS -handheld vs mounted oxblood On The Road... 5 05-14-2006 12:08 PM
