Old 07-19-2006, 03:05 PM   #1
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
AC Maintenance 101.........
Only getting a Hummmmmmmmmm....
1. Remove exterior cover.
2.Take out your leaf blower and give the AC a good blasting.
3. See what comes out of that fan ..Freak out,...Don't fall off the roof!!
4.Lube all moving parts and replace cover.
5. Go inside and with fingers crossed and hit the power up switch.
6. Yes...it fired up!
ID:	23725   Click image for larger version
enduroryda is offline   Reply With Quote
Old 07-19-2006, 03:10 PM   #2
Mel
Mel's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Great problem solving...
Glad it worked, but YUCK!
Mel
Mel is offline   Reply With Quote
Old 07-19-2006, 03:32 PM   #3
Images: 59
Nice tree rat.
Do you need any recipes or serving suggestions?
Old 07-19-2006, 03:36 PM   #4
HHP
HHP's Avatar
Yucca Valley , California
Talk about working the bugs out......
HHP is offline   Reply With Quote
Old 07-19-2006, 06:01 PM   #5
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Oh goody, road kill
Just slide that puppy on one of those little bamboo sticks and light it up with a Bic lighter,
Can U say Yumm……
Michael
ArtStream is offline   Reply With Quote
Old 07-19-2006, 06:01 PM   #6
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
i think we just found the july "photo of the month" winner!
john
you call them ferrets, i call them weasels.
Old 07-19-2006, 07:50 PM   #7
enduroryda's Avatar
1994 21' Sovereign
Sorry guys...Pretty gross post but it was getting to heavy in here so I had to lighten things up a bit seeing how Tin Hut is MIA and I do miss his posts....He always made me laugh so I just felt the need to give everyone else a chuckle. Pretty amazing huh...that rodent was pretty BIG.....YUCK!
Old 07-25-2006, 08:25 PM   #8
rebel beck's Avatar
1975 31' Sovereign
Oxford , Mississippi
Images: 35
Just be glad it was up there and not in there.
Becky
75 Sovereign (Peppy)
03 Chevy HD (lil Peppy)
Air# 9552
rebel beck is offline   Reply With Quote
Old 08-01-2006, 05:37 PM   #9
enduroryda's Avatar
1994 21' Sovereign
Follow up...
This weekend camping in all this humidity we fired up the AC and got considerable dripping inside so off to work I went....
Took the main AC cover off...than the inside coil cover off (big cover closest to the front of camper under AC cover)....there I found another nest ...nobody home thank God. What I did find was damage to the styrofoam drainage trough. The little bugger chewed it all up along the edge allowing all the condensation to drip right in. What I did then was cut a strip of aluminum flashing about a 1" wide to form a dam so that the water will flow down the path to the black drain tubes. I then siliconed it up good. Snaked the drain tubes to make sure no junk was clogging that up.
Hope the pics help someone down the road with pesky critters!
Oh...one more thing....Can anyone tell me what the blue and white wires are for coming in from the curbside? They looked like they were suppose to be capped off together but after further inspection the blue wire was never stripped back so no connection to the white...Any info greatly appreciated!
ID:	24136   Click image for larger version
Old 08-01-2006, 06:12 PM   #10
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
On my '73, all of the 110v AC wire is Romex. All of the DC wire is individual runs. White is always ground, 12v is always colored jacket. I can't imagine why it would be in that part of the ceiling, meaning it may have been an extra run of wire that was not used for some reason down in the cabin and inadvertently left underneath the a/c opening.
Maybe one of the HVAC guys will chime in. There is DC wiring associated with the AC unit itself, maybe left over from that installation. Either way, I would leave it alone.
www.nesa.org
Air No. 6427
Old 08-01-2006, 06:40 PM   #11
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
my guess is that it would be used for a roof vent fan if the ac was NOT installed.
i agree white ground blue hot.
john
Old 08-02-2006, 06:53 AM   #12
enduroryda's Avatar
1994 21' Sovereign
Thanks Jim & John for your help, I'll cap it and leave it alone.
Old 08-02-2006, 07:34 AM   #13
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Speaking of AC maint: where can I get some of that charcoal/sponge stuff? When I took mine apart to clean it it disintegrated...
Thanx, Bill
BillTex is offline   Reply With Quote
Old 08-02-2006, 08:25 AM   #14
Mookie's Avatar
1992 21' Sovereign
Oakland , California
Images: 60
Charcoal-colored filter material
Hey Bill - you can get that filter material at Home Depot. It is standard A/C filter material. It's inexpensive - buy a sheet, cut it to size, and you'll have plenty left over for another project.
-Mark
Mookie is offline   Reply With Quote
Gas appliances in an RV - routine maintenance lbrodsky General Appliance Topics 9 09-06-2007 03:17 PM
Hitch maintenance reminder... 85MH325 Hitches, Couplers & Balls 3 07-07-2003 09:13 AM
Roof Air Problams ViewRVs Mechanics Corner - Engines, Transmission & More... 22 01-28-2003 06:40 PM
Need help with Airstreamforums 101 !!! John Our Community 9 12-07-2002 12:55 PM
Fixing things-'RV Repair and Maintenance Manual Joan D'Andrea Our Community 6 09-19-2002 04:49 PM
