Old 08-02-2006, 04:25 PM   #15
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Another possiblity may be that the trailer originally had an A/C thermostat, and an A/C that didn't use it was installed. (Or could use it, but the installer was lazy.)
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 08-02-2006, 05:32 PM   #16
zamboni's Avatar
Have you tested to see if either of your wires has power? Looks like 12vdc wiring rather than 120 volt though....but use a multi-meter that can self adjust and read either ac or dc voltage to avoid damage to the meter.
I would alos guess it was probably for the roof fan which might have been eliminated by the install of the AC unit...might be able to use it for an additional light or other 12vdc need close to the area.
zamboni is offline   Reply With Quote
Old 08-02-2006, 08:18 PM   #17
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
That was my thought when I saw the wire. If it is live use it for a light. One more ceiling fixture never hurts.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 08-02-2006, 08:52 PM   #18
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
It's for frying up AC critters. 120 volt would be too much and char them to a briquet. 12 volt is just right, 3 minutes = medium rare, depending on weight.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 08-21-2006, 12:55 AM   #19
RVnDixie's Avatar
1975 28' Argosy 28
Homewood , Alabama
Critter Fritter!
Yikes! Makes me wonder what this varmint was looking for up there! And how in the world DID he get up there?
Joseph Tolliver aka "T"
Amy Tolliver
1975 Argosy 28D (work in progress!)
RVnDixie is offline   Reply With Quote
Gas appliances in an RV - routine maintenance lbrodsky General Appliance Topics 9 09-06-2007 03:17 PM
Hitch maintenance reminder... 85MH325 Hitches, Couplers & Balls 3 07-07-2003 09:13 AM
Roof Air Problams ViewRVs Mechanics Corner - Engines, Transmission & More... 22 01-28-2003 06:40 PM
Need help with Airstreamforums 101 !!! John Our Community 9 12-07-2002 12:55 PM
Fixing things-'RV Repair and Maintenance Manual Joan D'Andrea Our Community 6 09-19-2002 04:49 PM
